Question about Dyson DC44 Animal Cordless Vacuum
Motor stopped but it is showing that it is fully charged
The brushes on my Dyson V6 sweeper attachment won't turn although it is fully charged.
Your battery may indicate fully charged but if dead it will do that and not work for squat. If charged the motor should run and turn the sweeper with power. If motor runs but sweeper does not check for a stretched belt or one that may have fallen off the pulley.
Sep 06, 2017 | Dyson Vacuums
My robot vaccum stopped moving and the brushes stopped turning
is the battery getting fully charged? check to see that it is and it gets seated in the charging dock station correctly and charging lights come on.
Mar 05, 2016 | Bissell 1200-2 Bagless Robotic Vacuum
My Dyson DC35 stalls. I've thoughly clean it, so it's not a clog problem
1st make sure battery is fully charged.
Next, wash the filter, just follow the instructions in the manual.
If the filter is clogged the motor will try to run but then cut out to protect the motor from damage.
Mar 30, 2015 | Dyson DC35 Handheld Vacuum
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
Irobot manual
Is the light flashing green when you say it's fully charged? If it's yellow or red, that means it's got a low or no charge. The only time mine stops running is when something too big gets lodged in the brushes or it catches a sock or towel in the mechanism. It also can get stopped when if goes from one level of floor to another say 2 inches higher. It might need to be dismantled and cleaned out as well.
Jun 21, 2014 | iRobot Roomba 560 Robotic Vacuum
Not starting at all
Hi there, it's Jack at Dyson.
The issues with your DC44 Animal sound unusual, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
Dec 01, 2013 | Dyson DC44 Animal Cordless Vacuum
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Irobot discovery
It sounds like the battery is shot. These batteries only work for a couple of years and then they won't accept a charge any more. A common mistake people make is recharging them before they need it. This will make the battery "lazy"
Contact the manufacturer for more info.
Dec 09, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Dyson DC44 Animal Cordless Vacuum Logo
16 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
