Question about TrendTimes.com Toys & Hobbies Stencil Crescent Moon W Face
Need Remote For1988FireEng. Trk. Snorkel No.1 R/C
Have 1988R/C Bright Fire Engine TruckNYFD Snorkel No.1 No Remote need a Remote
My 1995 nissan trk back fired and blew my muffler and stopped running. What could that be?
the only time i have seen this is when the exhaust is blocked or weak. back fire would not normally do this. replace the muffler as you say. and check that the timing lines are in the right place. have you had engine management light come on at any time while driving. if time ok and engine has no lumps while driving then it would just be the muffler fault.
Mar 15, 2016 | Nissan Cars & Trucks
How do i fix fuel injected engine ignition coil. sparks, wire with connector ? where wire goes, if needed??
what you need is to take it to a good auto electrician and have him/them fix it .
Oct 28, 2015 | Motorcycles
Why wont my engine fire?
check for spark...just because you hear fuel pump, may not have correct pressure...remove snorkel and artificially enrichen fuel to see if it starts
Sep 14, 2014 | 2001 Pontiac Grand Am SE
I need a remote controller for a sanyo trk 6/17
Hello
Just choose any universal remote control, which has setup codes for Sanyo DVD player. You can get these details form the code list that get alongwith the universal remote control. OK.
Mar 06, 2012 | Sanyo Televison & Video
94 gmc sierra 4.3 v6 manual, won't turn over, can hear fuel pump start when accessories turned on..won't fire, girl who needs help
The first thing I would check is fuel pressure. This type of fuel injection requires a minimum fuel pressure in order to operate. If fuel pressure is as little as one psi below minimum the vehicle will not start. You can try squirting a couple of shots of carb spray into the air snorkel while somebody cranks the engine over. If the engine starts and then dies you now you fpdeffinetely have a fuel issue. If the engine still won't start check for spark. Let me know what you find. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 07, 2012 | GMC Sierra Cars & Trucks
Do i need to remove the air cleaner assembly to change spark plugs in my 1998 k1500 chev pu with 5.7 liter engine?
you may have to just to make access to some of the plugs easier so the air snorkel is not your way and the hot air tube that runs from the air cleaner to the exhaust manifold.or remove the air snorkel and the hot air tube.its not hard to move the air cleaner out of the way.
Apr 20, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I bought this snorkel used and put it in my bathtub last night and it filled with water. The lower chamber is filling to the point I can't even blow it out. Is there something I don't know?
From what you've described, you have a self-draining snorkel (at least it would be if working correctly). There will be a simple diaphragm valve at the lowest point of the snorkel, it's usually made of a silicone rubber disc and in use is held closed by external water pressure. It can also be held open if there is any grit or sand in it, if it is damaged or if it's simply hardened with age.
All you can do is clean it and make sure it seats correctly. If it has failed in any way or if the diaphragm is simply missing then buy a new snorkel as they don't need to be expensive.
There's a good reason that many divers still prefer a simple j-tube snorkel and it's because there is nothing to go wrong. I personally do use a self-draining snorkel but I'm careful to inspect and clean the valve before and after every use and always have a spare snorkel in my dive bag.
On an unrelated matter, if the snorkel has any kind of device on the open end to prevent water from entering then I strongly recommend that you remove it. They're restrictive to airflow and are potentially dangerous. There is no substitute for simplicity and for learning to use a snorkel correctly.
Jul 09, 2009 | Tabata Usa Tusa Snorkeling Two Window...
Vaccum hoses are missing. 1986 Nissan 720 4X4
truck normally has a vacuum hose routing diagram on under side of hood on drivers side.also look for metal tag on center of engine compartment fire wall which gives you a motor id @ and trk model # you can then know what engine vacuum diagram you need.i have a diagram for an 86 720 series Z24 carb engine that can be copied off of truck..chris
Apr 02, 2009 | 1986 Nissan Pickup 4WD 1986
The right snorkel for me
"A snorkel must fit comfortably in your mouth, allow you to purge water out of the mouthpiece and hose quickly and help you to swim efficiently. But, the most important characteristics to remember when choosing a snorkel are its length and the diameter of its barrel. Snorkels must not be too long or too short. If a snorkel is too long it will be difficult to breathe because the barrel will fill up with carbon dioxide. Every time you breathe out carbon dioxide through your snorkel your breath must travel up and out of the barrel of your snorkel to allow you to draw oxygen back down the barrel and into your lungs. If your snorkel is too long you will only push a percentage of the carbon dioxide up and out of the barrel during your exhale. You will need to inhale oxygen before all the carbon dioxide has been pushed out; leaving the percentage of carbon dioxide entering your bloodstream higher each time you take a breath. This cycle could lead to suffocation. If a snorkel is too short it will constantly fill with water, requiring you to constantly force the water out of your snorkel which can be very exhausting. The inside diameter of your snorkel must be approximately three quarters of an inch or 1.9 cm. If the snorkel is thinner than .75 inches it will be difficult to breathe because there will not be enough room in the barrel for you to draw enough air into your lungs. This will cause you to breathe harder and rapidly, which could cause hyperventilation. If the barrel is thicker than .75 inches it will be too large and will be uncomfortable to use and attach to your mask. Learning to attach your snorkel to your scuba mask to make sure it is easy to grab and use is an important part of safe scuba diving practices. Snorkels are attached to the left side of your mask with a snorkel keeper. Snorkel keepers are either plastic or rubber and most use a post-hole closure. Each snorkel keeper is different and attaching your snorkel to your mask with a snorkel keeper requires practice. If you will detach your snorkel from your mask after each dive you should practice attaching your snorkel, as it can be a little tricky. Alternately, you can leave your snorkel attached to your mask if you are diving more than once in a day. "
Dec 01, 2008 | Aeris Snorkeling Bag
Snorkel need issue
Every scuba diver spends time on the surface while preparing to descend for a dive. A snorkel allows you to conserve energy by letting you keep your head in the water while swimming and enjoying the pre-dive sights without ever having to remove your head from the water.
TrendTimes.com Toys & Hobbies Stencil Crescent Moon W Face Logo
730 people viewed this question
Top TrendTimes.com Toys & Hobbies Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a TrendTimes.com Toys & Hobbies Winter Sport Expert? Answer questions, earn points and help others
