Question about Akira HPT5001D Television
TV TROUBLESHOOT Good day to you sir, i have a problem with my tv, first it was a dead set, i try to fix by replacing power ic STRG6653 and 4R5WJ resistor. i test it but it only indicate standby. then i replace the system ic LC863224A to turn it on and it turn on, but the problem is the screen is only black, no volume indicator, no channel, no menu on the screen. CRT is on, flyback is good, what do you think is the problem? pls help me i really need your response. alvin concepcion(icaru98@yahoo.com)
Step 1 check the ABL, step 2 check the junggel ic
Posted on Sep 08, 2008
Mitsubishi ws55315 will not stay on
I'm sorry to break it too you, but you're TV's most likely dead.
Before throwing it out or getting it fixed, I would recommend this:
>Unplug the TV from the wall socket.
>Hold the power button on the TV with it unplugged
>Plug the TV in whilst holding the power button
>Keep holding it until the TV comes on (if it does).
Otherwise, search locally for repairmen. They would comonnly charge around $100 to $300.
Good luck and have a nice day! :)
Jul 14, 2017 | Televison & Video
No power to tv
Good day!!!
That problem is usually cause of bad or dead set power supply board..
You can buy the power supply board online just search the part # that usually found on the said board printed in sticker it is combination of letters and numbers..
Try to replace the board to fix your TV..
Hope it helps please rate my answer!!!
Thank you
Jan 12, 2012 | Sony BRAVIA Televison & Video
Have a Mitsubishi WS-65819 (about 9 yrs). over past 3-4 weeks the color started to skew (3D like arch on top and bottom), then yesterday, the TV totally powered down and will not power up, totally dead. ...
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Aug 09, 2011 | Mitsubishi WS-65819 TV
When adjusting the convergence, ended up with a concave screen, then it smoked. Is this a power supply, or worse? Is there any advice that you could give me on this...
Thats usually indicating the ICs have failed. Usually with that model its best to replace the board rather than try replacing the individual components as ther are several 3.9 ohm resistors that will need to be checked and possibly replaced along with both ICs. www.tvcircuitboards.com should have the replacement board for your model if you need one.
Jul 08, 2011 | Samsung HCL473W 47" Rear Projection...
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No power or red led fuse good .toshiba 27df46
Hello Hloggins, hi, your power supply is not producing the pulse needed to start the switching. check for the IC on the oscillator part of the power supply, you need an Oscilloscope to test this. if there is no scope. i suggest you replace the IC.
May 20, 2010 | Toshiba 27DF46 27" TV
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Same problem with mine
Based on what you have described, you have lost the power supply or main board. Unplug unit, carefully lay it of the front side, pull about 10-20 screws out of the back, look at the electronic boards, if you know what caps are, run your finger across the top of the caps,if they are swelled up, then that board is bad. Those boards go for 150.00 to 500.00 each.
Sep 23, 2009 | Samsung LN-S4051D 40 in. LCD Television
TV fixing
On some of these sets i have notice a resistor opens leading to horz. osc. circuit allowing set not to come on as long as the diode you replaced is not shorting out again . Follow the path this diode takes to that circuit . It's been awhile since i've worked on one of those but they were a common problem . Also include the model # if this does not take care of problem and i'll do alittle research on that chassis. Good luck
Feb 28, 2008 | Televison & Video
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
272 people viewed this question
Top Akira Televison & Video Experts
jasbo
jasbo
ray gallant
Are you an Akira Televison and Video Expert? Answer questions, earn points and help others
