Question about Acer Aspire 1800 Notebook
Acer aspire 5734Z not booting. Acer logo shows and press f2 for setup
SOURCE:
  • 70 Answers
SOURCE: setup password lost in an Acer Aspire 9410 laptop
The best way to this is to reset the cmos on the motherboard of the Laptop. This will reset the bios password.
To do this unplug all power from the unit and remove the battery. Remove the cover from the laptop so the motherbard is exposed. Look for the cmos battery (about the size of a nickel) and remove the battery for about 30 mins and then replace. Reassemble your laptop and you should be good to go.
Posted on Feb 25, 2009
  • 4 Answers
SOURCE: ACER ASPIRE 5100 WONT BOOT
Try taking all of your ram chips out and re-seeting them. I upgraded to 4 gigabytes in my 5100 and it wouldn't boot, just a black screen with some cdrom and hd activity. Or try running with just one ram chip and then going into the bios and setting everything to default. this made my system bootable again.
Posted on Feb 26, 2009
SOURCE: my acer aspire one netbook tries to boot ,but then
i was able to go on the acer website on another pc and found that if when you turn on your acer and hold down ALT key while hitting F10 that will bring you to a system recovery screen. you can restore factory settings from there. It will wipe out all of your documents and pix but it does fix the problem.
Posted on Apr 22, 2009
  • 788 Answers
SOURCE: Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Posted on Sep 26, 2009
  • 5 Answers
SOURCE: ACER ASPIRE 5532 LOCKED UP, WON'T GO PAST THE
1. Turn the Laptop off 2. Remove the battery 3. Disconnect the AC adapter from the laptop 4. Disconnect any peripheral devices from the laptop such as printer usb cables, PCMCIA cards etc. 5. Push and hold the power button for 60 seconds then let go 6. Connect the AC adapter to your laptop 7. Push power button to turn on the laptop 8. If this resolves the issue shutdown the laptop connect the battery and turn laptop back on
If issue is not resolved restart the computer and begin tapping the F8 key repeatedly until you see a screen that gives you options to enter different modes. Highlight "Safemode" and press enter. If the computer boots completely into safemode you likely have a driver that has corrupted or a hardware device that has failed. Likely driver failures are video card drivers. Got to Device Manager and uninstall the video card driver and restart the system. You can do this with other drivers as well.
Posted on Mar 05, 2011
My aser aspire say the oprating system not found but the hard disk has the oprating system and ot works properly what can i do to fix this and how can i enter in bios mode
Shut down your Acer Aspire if it is running. Once the computer is off, press the power button to start it. Press "F2" immediately while your computer is booting up and displaying the "Acer" logo. Keep pressing "F2" until the BIOS Setup screen appears.
Aug 16, 2016 | Aspire Computers & Internet
HOW to tget to bios acer aspire AST180-ED400A
Immediately after pressing the power up button, start repeatedly pressing F2 while the Acer logo is displaying. The Bios setup screen should appear. If you press F2 too soon, the keyboard may not have initialized yet. If you press it too late, Windows will proceed to launch. Press it once, wait a second, press, it again, wait another second, and repeat this while the Acer logo is displaying until you see the bios setup screen.
This is standard approach with most Acers. That said, some laptops may defer to either Ff being the key to press or CTRL+ALT+EXC. Such would be entered as the above mentioned F2. Your Aspire appears to be a desktop and I suspect F2 will suffice.
Feb 19, 2015 | Acer Computers & Internet
My acer laptop showing ACER logo and press F2 to setup and restarts every 5 seconds . Changed 2 GB RAMs one by one and checked up. But problem not solved. Only on removal of battery the laptop could...
If machine not booting it could be a bad cmos, hard drive, mo bo, peripheral, corrupted OS, bad power supply, bad memory,
Remove the hard drive and see if it posts and then gives you message that there no boot drive If that does not happen then machine is not even posting which means something is wrong with the cmos. - not a good thing.
Sep 23, 2017 | Acer Aspire 5742 Notebook
My acer aspire9410 disply is blank,i entered many time bios setup key F2 but it not showing bios setup page, pls help me to get in to bios page. before i tried lot one it was showing but it showing like...
-changeing bios-first restart computer then press[ f2] then get on key board use arrow key on key board go down you will see your boot log is on f2,change that on a f12, now push f10 to exsept settings now when asked restart computer then f12 then run windows under D:drive.
Feb 26, 2011 | Acer Aspire 9410 Notebook
I want to reset my bios aspire 4730z.. please help me... i want to downgrade my laptop from win7 to xp...when i refomat to xp blue screen appear and some saying error.. please help
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed). You can set the bios to default if needed.
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the installation disk, follow the prompts to press any key to boot from cd.
  8. When you get to the screen that shows the partitions you should delete all of them, and then create new one. format and install your os. I hope this helps you good luck
Sep 24, 2010 | Acer Aspire 4730-4947 Notebook
Acer 3000 Series Laptop Splash screen does not appear at startup when pressing F2 on the post page. Therefore unable to acces bios. Has e-manager but cannot access bios through it either. Welcome all...
It sounds like the Acer logo has been turned off in the bios settings. As soon as you hit the power button, start tapping the F2 key until you see the test appear "entering setup". Once you are in the BIOS, look for the Logo settings as far as being visible during Boot up. I've seen this setting on other systems so I am thinking the Acer should be similiar.
Jun 19, 2010 | Acer Aspire 3000 Notebook
I have an acer aspire one aoa150 that starts to boot and shuts down afer about 10 seconds
Sounds like a corrput hard drive or motherboard. Get it checked out or replace both and it will fix it. Its a expensive solution.
Jul 06, 2009 | Acer Aspire One PC Notebook
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 1800 Notebook Logo
75 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
