Home | HP | Photosmart 3310 Printer | Black doesn't work on ...
HP Photosmart 3310 Printer
Problem for HP Photosmart 3310 Printer
Black doesn't work on HP psc 1350 printer
By tammy_bowe on Jun 07, 2009
I have an HP psc 1350. The black does not print at all (not even a trace). Color does print however. I replaced the black ink cartridge (56), but still no luck.
Solution #1
posted on Jun 07, 2009
Somewhat Helpful)
joecoolvette
Rank: Guru  HP Expert Computer Hardware  Expert
Rating: 92%, 541 votes
Printer unplugged from power, and USB cable unplugged from computer. Open the printer again, and take all of the ink cartridges out. You may want to don a pair of dishwashing gloves, (or something similar), to keep any chance of ink getting on your fingers.
Use a clean, lint-free, cloth, and soak it in as hot a water as you can stand, then wring it out until it's damp.
Wipe the area of the inkjet ports on the body of the printer.
To explain where these tiny ports are located, let's go back to the ink cartridge itself.
Before you installed the ink cartridge, you had to remove a piece of cellophane tape, or aluminum foil.
This area on the ink cartridge, is where it's inkjet ports are located.
Where these inkjet ports are on the ink cartridge, and where they line up on the printer body, is where the corresponding inkjet ports are on the body of the printer.
I'm suggesting, that ink has dried in these inkjet ports for the black ink cartridge. The warm water cloth will help dissolve this ink, and clear the inkjets on the printer body.
I would wipe in one direction only, and turn the cloth to a clean area, as the dried ink builds up on it. When hardly any ink is present on the cloth, I would then use a hair dryer set to low. Move the hair dryer constantly, and do not hold it in one place.
You want this are dry before you reinstall the ink cartridge. Once you are satisfied it is dry, reinstall the ink cartridges, close the printer.
Plug the printer back into power. (Dry hands!)
Plug the USB cable back into the computer. Wait until the printer has rest itself back up, then turn press the Power On button.
(Some printers rest themselves when they are plugged back into power, some rest themselves only when the Power On button is pushed)
I would align the heads, and print out a test sheet.
You may have to go to Diagnostics, and have the printer check itself. (Start>HP>Photosmart>Help,
will guide you to the Diagnostics section)
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart 3310 Printer
Questions and Unsolved Problems for HP Photosmart 3310 Printer
Do you recommend HP Photosmart 3310 Printer?
Answer
Answer
hp scanner 3310 all in one won't work with imac OSX 10.6.1
Answer
Hi - I have a Hewlett Packard Photosmart 3310 All-in-One. Have been copying on it successfully for 3... (More)
Answer
Does not print black. Has new cartridge and indicates full black ink.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Photosmart 3310 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
