Question about T-Mobile Sidekick® 3 Cellular Phone
No charge My sidekick 3 will not charge, I have plugged in numerous chargers and it still will not charge. However it will light up if i turn it a certian way for a nanosecond. it seems as if it has a shortage...
  • 425 Answers
Check the batt mayb your batt drained off... try using other batt.  if still doesnt work, probably you have a software or hardware failure...
but if it works w/ other batt try charging it, if still doesnt charge your phone charging section have a prob...
just visit your nearest service center to help you...
Posted on Oct 26, 2007
My sidekick 3 won't turn on and i just got it today
Oooh, bad news. You probably got a sidekick 3 that had a bad charging port. Return for a refund if you can.
the Sidekick 3 has a charging issue thatcrops up after awhile. It will just not charge the battery.A good way to tell is if the orange light comes on but the phone never charges.
You can get an external battery charger for the sidekick for about 25 dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 13, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
Broken Sidekick 3 - no indicator lights
The charger on the sidekick 3 is notorious for going bad. You will see the orange light lije it is charging but it is not.
An easy workaround is to get an external battery charger and extra battery. Runs about 35 or you can get it repaired for about 75 dollars.
Check out the following link for the options
Workaround for Sidekick 3 Charge Port Broken
Mar 23, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 Charging Question
I can tell you the sidekick 3 will not operate properly with out a back cover. In fact, if you remove the rear cover while powered on, it will post a warning message on the screen.
Because you tested and successfully operated the phone with out complication with a back installed I fell confident you should have have any problem with the phone when your back cover arrives.
Good Luck
sponsored by Cell Phone Technicians
Dec 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Jake-
That is the right button. The charging port is probably bad. This is a common occurence on sidekick 3's. Does the orange light come on but it nevers seems like it is charging?
The best thing to do is get a edocking cradle that has an external battery charger. It will allow you charge the battery seperate form the phone.
See link below
http://fixmysidekick.com/shop/repair-replacement-parts-for-sidekick-3/Sidekick-3-Spare-Battery-Charger
Sep 10, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick wont charge
wakesk8er02
The sidekick 3 has a known issue with the charging port going bad. The orange light will usually come on but it doesn't charge the battery.
you can try www.cellulardr.com or you can do a work around that will cost less.
Most people will buy a cradle charge that has a built in spare battery charging slot. This allows you to charge the battery seprate form the phone. ?It is about 25 dollars on ebay. Its also a good idea to get a spare battery so you can have one charging at all times.
Sidekick 3 Spare Battery Charger
Sidekick 3 Batteries
Jul 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 charging problems
Ok, is the sidekick 3 brand new out of the box or new to you.
The sidekick 3 has an issue with the charging port being bad.
I would contact the person who you bought it from and get a refund.
The other option is to get an external battery charger and charge the battery that way
check the link below for those
Sidekick 3 external battery charger cradle
Jun 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 wont turn on
heres what i would say. let it charge for more than hr, and this bring it up to speed..if not i believe the battery may be defective, i just experienced this problem last night..the battery happen to be defective, then put another battery after awhile i went to sleep woke up, and it wouldn start...i let it charge for a while and it was good as new
Feb 11, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
53 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
