Question about ConnectGear UG102 KVM Switch
Keyboard "hot" key problems
Sometimes when I'm working on some of my applications where I need to you the "ctrl" key with another key on the keyboard, the menu comes up and locks up my keyboard for a few seconds.  Then, sometimes it changes the configuration of the keyboard when the menu shuts off.  I have to restart my computer.
  • 188 Answers
It look like your windows currepted or u have any virus on u r pc..
1 st chek u r pc for virus man...
if its ok...
u can reinstall u r windows...
dont forget to tell me u r problem solved or not
best regards & best of luck..
Posted on Oct 26, 2007
    SHIVAJI YADAV Nov 05, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..
Can't use PrintScreen key on Logitech's "Cordless Internet Pro" keyboard. Key is on upper right of keyboard with "Prt Scr" above "SysRq" on the same key. I've...
It's what you do AFTER PrtScr that matters.
Basically the key takes a snapshot of the screen and stores it on the Clipboard. Next PASTE it into an application like Paint and Print from there. Or paste into a document you are working on that requires a screen clip (after editing it, if needed).
Rate me 4 stars is this helps!
Oct 25, 2017 | Logitech 967437-0403 Keyboard
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
Ctrl key doesn't work
this problem is not uncommon.
go in to control panel program then into keyboard settings and select your keyboard this should fix it for you .good luck
Aug 02, 2009 | Toshiba Satellite A40-S161 Notebook
Problems with the keyboard
Sticky keys can sometimes be fixed by hitting right shift key 10 times quickly (I'm not lying!!), and or the culprit key (x) the same way. Try that and if it doesn't work, reboot and type. If it continues, please try another keyboard.
Nov 20, 2008 | Computers & Internet
Compaq laptop can't get the ? symbol
Looks like the French keyboard mapping is still in effect.
You can try changing the keyboard keys back to where they were by pressing:
Left CTRl + left Shift at the same time. then try typing the ?/ key. You may have to try this a couple of times to get it to work.
If it does work, try the right ctrl/left shift key.
Also found this:
Control Panel, Regional and Language Options, Keyboards and Languages,
Change Keyboards. Select the keyboard you that's causing you grief and
choose Remove.
If you don't remove the keyboard map, when this switch happens, you'll have
to exit the application you're in (Outlook, for example), change keyboards,
and restart the app. Changing keyboards without restarting the app doesn't
seem to change the mapping.
Hope this helps!
Sep 06, 2008 | Computers & Internet
Nexxtech keyboard problem
Is it just Dirty or actually broken? It may take dissasembly to determine whether it needs cleaning or not, another alternative is to assign Ctrl to another Key (Maybe F12) that you don't use a lot... C
May 26, 2008 | Computers & Internet
Keyboard ctrl key not working
try another keyboard to check if there is something wrong with your os settings.
1. if it works with the new keyboard , your keyboard is the problem.
2. if it does not work w/ the new keyboard still the same problem, os settings in the keyboard is the problem
Mar 28, 2008 | Computers & Internet
Automatically ctrl key is pressed
first make sure that the keyboard is ok, you can press the ctrl key and compare with the feeling when press other keys, to see if there is different, may be some thing stuck there, if there is no problem, check the driver is installed correct, you can get the keyboard type from the check list of the computer or contact with the supplyer, and install a correct driver
Aug 02, 2007 | Compaq (12XL310) PC Notebook
ConnectGear UG102 KVM Switch Logo
220 people viewed this question
Top ConnectGear Computers & Internet Experts
David Payne
David Payne
Are you a ConnectGear Computer and Internet Expert? Answer questions, earn points and help others
