On power up with either Battery or AC or BOTH DC-IN LED flashes a code I believe HEX 27 Before problem PC worked very well
SOURCE: Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
SOURCE: Dell XPS M1330 PC - battery not detected
The error code 0146 and the battery are two separate problems. First the battery problem is simple, it's bad and needs replaced. It being bad can refer to a developed short, a fail safe kicked in, or it's simply worn out. It is a battery after all, ad they don't last forever, the more you use them the quicker they wear out. A bad battery causing an issue is vary common with Dell machines, and a false battery reading with a failing battery is also common. The orange flashing battery light is the indicator that the battery isn't working properly, either by fail safe or wear.
The error code 0146 Is from the short test on the hard drive and indicates the a sector is going bad, and eventually the hard drive is going to fail. At this point, your hard drive may last days, or months. Either way, I suggest that you back up all important data, and purchase a new hard drive for the imminent failure. You might even go ahead and set it up, this way you'll be prepared when it does go, and you won't have any downtime.
SOURCE: Hellow Dear, My acer aspire 4935
First, you need to make sure your power adapter is providing enough
power to both run the laptop & charge the battery. A very good way
to do this is to compare your laptop voltage & ampere requirements
(written on a sticker on the bottom of the laptop) with the voltage
& ampere ratings of the power adapter. Voltages should be the same,
or the power adapter's voltage about up to 0.5 volts more than the
laptop's voltage rating. Amperage of the power adapter should be at
least equal to or greater than the laptop's rating. It should never be
less than the laptop's rating, or else the power adapter will be
providing insufficient amperes to charge the battery. Of course, the
power adapter's nominal amperage might be ok, but it degraded on usage.
You can verify this by testing using a good or new power adapter.
If
the battery did not charge using the new power adapter, take the battery
off the laptop, & using a dry tooth brush, scrub in between the
fins of the battery connector on the motherboard & on the battery it
self, then put the battery back into the laptop & try again.
If
this still did not resolve the problem, then the battery itself could be
bad. Try it on another laptop, or try a good or new battery in your
laptop.
If this did not work, there might be a possibility that the
charging circuitry on the laptop's motherboard is defective & needs
servicing. In order to do this, the laptop needs to be disassembled
& the motherboard checked for defective/burned out components in the
area near the DC jack. Any defective/burned out components found should
be replaced, or you might need to replace the laptop's motherboard
altogether.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
