Question about Sony Cyber-Shot DSC-T3 Digital Camera
Camera lcd and photo problem
I used the camera after 14 days, the last time I used it was on 12 Oct, the camera was working fine without any trouble and the picture quality was good. This morning I switched it on and to my surprise the lcd was giving a smudged look. All the colours diplayed were bleeding a lot and the display was inaccurate ie, the objects appear different. Even after I took a photograph the photo was completely out of focus( even on the autofocus mode) and the colour reproduction was wrong. This camera was kept in the case for the entire period and I was completely shocked to see something wrong. I tried to reset the camera but apart from the date and other settings the LCD and autofocus didn't show any difference.
Re: Camera lcd and photo problem
The Dreaded CCD problem,it seems.
Time for a visit to the service centre.If it is under warranty,rejoice,for they would replace it free of cost,else,be ready to shell out about 200$.
Best of luck
Posted on Oct 26, 2007
0 characters
3 Points
Why Fuji Finepix XP20 won't take photos?
Check the settings of the camera. Put the recording mode for stills (photos) to auto, so the setting can't stop the camera from taking a picture. If you are in one of the manual modes, and the system calculates it won't be possible to make a picture (to dark, to light, or out of focus and so on) it won't react when you press the shutter release button.
Please use the manual, so you will be able to solve this every time it happens to you. The manual is still online.
Jul 22, 2014 | Fujifilm Finepix Xp20 14-megapixel 720p Hd...
White Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD.
Please click HERE
And in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Feb 21, 2008 | Fuji FinePix S5000 Digital Camera
Why fuji finepix XP20 won't take photos
do you get a message? Try a different card or plug into pc to see if there is anything on the card. After the card, it becomes very complicated.
Camera working fine last time I used it. Havent dropped it or anything, today the photos come up over bright with visible horizontal lines throughout. Have check all settings and reset.
You will need to check if the brightness is in the LCD of the camera or is in the picture.
If the pictures on loading to your PC is good then the fault is in the LCD of the camera.
If not the CCD of the camera is faulty as there are errors in the main processor or CCD.
Oct 11, 2010 | Pentax Optio M40 Digital Camera
Last time i used it wasworking fine next day got a 'card error'
Did you try formating the memort stick.
This will clean up any error in the stick.
Don't let the battery in the camera run to low, messes with the flash memory.
Mar 10, 2010 | Casio Exilim EX-Z1200 Digital Camera
Flickering and loss of colour
Problem now solved. I switched the camera on and off a few times and took several test photos. After a few minutes the problem resolved itself. I suspect the cause was condensation, but cannot be sure.
Jan 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
My digital camera gets blurred in day times.
it may be the setting you are taking pics on select the DAYLIGHT MODE it may be in night mode
Jun 22, 2009 | Canon PowerShot A470 Digital Camera
LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
Jul 22, 2007 | Nikon CoolPix S2 Digital Camera
Has my F717 kicked the bucket?
If the LCD is "smeared" in record mode, it isn't the memory stick or any of the other solutions you've been offered. It's one of the following, I would guess: 1) condensation in the camera 2) loose or bad connector to the CCD or power supply 3) Camera is history. Hit eBay and get a new one BTW, It costs about $175 for repair by Sony (at least the last time I had a repair done on a 717). It's probably worth it as long as the rest of the camera is in good shape. Definitely cheaper than buying a new one or a used one. Sorry about your problem...
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-T3 Digital Camera Logo
51 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
