Home | Canon | NP 6050 Copier | The problem in canon 605...
Canon NP 6050 Copier
Problem for Canon NP 6050 Copier
The problem in canon 6050
By lawrens_611 on Jun 06, 2009
e531
e530
Solution #1
posted on Jun 29, 2009
Not Rated)
ronnie59
Rank: Guru  Canon Expert
Rating: 93%, 69 votes
this error from sorter/stapler unit if this problem is repeated
disconnect the sorter and use copy tray,sorter must be serviced
E530
Main Cause The alignment plate home position sensor (PI6) is faulty. The alignment
motor (M3) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The alignment plate does not leave home position when the alignment
motor has been driven for 2 secs.
0002 The alignment plate does not return to home position when the
alignment motor has been driven for 2 secs.
E531
Main Cause The stapler home position detecting switch (MS7) is faulty. The stapler motor
(M6) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The stapler does not leave home position when the stapler motor
has been driven for 0.5 sec.
0002 The stapler does not return to home position when the stapler motor
Was this helpful?
Yes
No
Popular Solutions for Canon NP 6050 Copier
Questions and Unsolved Problems for Canon NP 6050 Copier
Do you recommend Canon NP 6050 Copier?
Answer
Answer
how to remove the MITAC kyocera km 1500 repair and remove or reset the error code c-6 20
Answer
we are getting continual jams in areas 4 & 5 even though there is no paper to remove. any... (More)
Answer
cutting image when copying using rdf
Answer
i want a copy of manual and troubleshooting.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon NP 6050 Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1489
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
