Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool not agitating
I have a 12 year old Whirlpool top loading washing machine.  The center piece (agitator?) will not move when I try to spin it when it is filling with water.  It will also not agitate once the machine is filled.  Any ideas of the problem and if I need to call a pro or get a new machine?
  • 4 more comments
  • jjames Nov 03, 2007
    hear a grinding noise when I put it on the spin cycle. It does fine on the rest of the cycles.
  • Anonymous Nov 12, 2007
    I have the same washer with the exact same problem .. its not the lid switch its the transmission which controls the adjatation and spin of the tub.
  • msmaam Nov 12, 2007
    I have the exact same problem. I don't want to have to call someone out if I can do it myself.
    please help. I have six children and the clothes need to be washed.
  • jtvictoria Sep 07, 2008
    I have a whirlpool lsr7233dq1 and it will not agitate or spin.
  • clancyh Mar 06, 2009
    My whirlpool top loader direct drive washer will not agitate after water is filled.
  • Anonymous Mar 17, 2014
    washing machine wtw5700sw0 fills up with water, but doesn't spin or agitate
Hi everyone - I ended up calling a repairman. It was small part that needed to be replaced. It cost me $65 for the visit, $20 for labor and $20 for parts. The repairman told me it would probably be good for another 5 years.
Posted on Nov 13, 2007
Asking a questions does not solve the problem.
Posted on Nov 12, 2007
Where is the lid switch?
Posted on Nov 03, 2007
    Problem Solver:
  • 19 Answers
Check the lid switch
Posted on Nov 01, 2007
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Washer is not rotating fully during wash cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Some Kenmore washers have a two piece agitator. The lower section will rotate back and forth both ways.
The top section has "agitate Dogs" that allow it to rotate only one way (to keep the clothes moving downward.
If yours has a two piece agitator there shouldn't be a problem.
Oct 18, 2009 | Kenmore 24032\24036 Top Load Washer
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Series 70 top load barely agitates....
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Whirlpool Washing Machine Won't Agitate
Hi friend...
it is usually caused by anything stucked below tub,if its not then if is actualy timer,,,check them both...
thank u.....
May 03, 2009 | Whirlpool Washing Machines
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
May 15, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
378 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
