Question about HP Deskjet 6940 InkJet Printer
Hp printer I have a hp 6940 deskjet printer. When I push print it brings up a fax wizard box and trys to get me to send a fax. will not print off the net. tried calling tech support but unfortunately i couldnt understand the person on the other end
  • 121 Answers
Re: hp printer
THis is probably a problem with your driver.  Look through your installed printers on your computer.  See if the HP 6940 says fax somewhere on it.  If so, make sure it's not set as your default.  Set the other one as your default.
Posted on Oct 26, 2007
0 characters
3 Points
When I click on file and then click on print the screen that comes up showing the name of my printer (hp6940 desk jet ) small wording comes up saying error=offline and my printer will not print the message...
-Try to turn off and turn on your printer
-check your connection
win xp
-go to start/setting/control panel/printers and faxes
-right click "hp deskjet 6940" and click on "use printer online"
win 7
-go to windows logo/control panel/devices and printer/right click on the printer driver, click on "see whats printering" click printer and uncheck use printer offline
Sep 04, 2010 | HP Deskjet 6940 InkJet Printer
Is a HP Inkjet Print Cartridge 94 compatible witha Hp Deskjet 6940
Not according to the HP site.
It shows 96, 97, 99, and 100.
Go to: HP DeskJet 6940 Supplies
Thanks for using Fixya.
Oct 28, 2009 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 stopped printing
Try This :
Delete the printer icon from the Printer and faxes folder; Disconnect the USB cable (If connected through USB);
Put in the driver disc; Goto my computer; Right click on the black HP logo click on Explore;
Click on UTIL(Folder)- click on CCC(Folder)- Click on Uninstallation L1 ;
Take out the CD restart the computer
Download the sofware from;
Select the OS;
Click on download
Save it to your Desktop
Run the software;
Click on Add a Device and reinstall the driver;
This should resolved the issue
Aug 11, 2009 | HP Hewlett Packard Deskjet 6940 InkJet...
HP Deskjet 6940. Carriage is stuck in park position. Won't move either automatically or manually. Is there some way of "unsticking " it??? Appears to be mechanicaly retarded
Sometimes you can reach under the printhead with a pencil or screwdriver tip and push back the cleaning assembly. That allows you to clean the cleaning assembly so it might not get stuck again. You need to find something solid to push on, directly under the print cartridges. You will hear the motor turning as you push gently.
Jul 15, 2009 | HP Deskjet 6940 InkJet Printer
Try double-clicking on the printer in the Printers and Faxes folder and clear any pending jobs. Turn off and disconnect the power cable from the printer for a few minutes to clear its buffer. Keep the paper removed from the tray during this process and only re-insert it after the printer has stopped attempting to print. When the spooler and buffer are cleared normal printing should resume.
Nov 11, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Not printing after deleling muti produces ie;6940 to set as default printer
remove all of the printer job from the print queue.
remove the printer from the prin and fax dialog box.
go to control panel>> add and remove porgram, uninstall the printer.
reinstall the printer w/o the pirnter connected to the PC.
connect the printer to the PC after the PC restarted.
Sep 06, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Jul 14, 2008 | HP Deskjet 6940 InkJet Printer
Printing envelopes
Just press the blinking down arrow button and the printing will start
Jul 02, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
124 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
