Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv2626r shows red and hue cannot adjust
Sony tv power up for 2min and then shut off.also shows red
    Genius:
  • 1,694 Answers
Probable bad picture tube = replace set.....T.
Posted on Oct 26, 2007
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Pioneer SD-P55A5 shut off during use and wont advance past standby mode
This is a problem related to the hue controlls in the TV. It is quite common.
Fix: You can go into the TV settings and try adjusting the hue/tint there.
If adjusting settings does not work, request help from a technician to fix it for you since it will take adjusting the hue internally and if you do not do it correctly it can damage your television.
I hope this helps ya!
Jul 28, 2008 | Pioneer SD-P55A5K 55" Rear Projection...
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
Jun 15, 2017 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KDS 55A2000 Unit has no Blue hue... only green and red. checked the inputs and sat box (sub'd) all the inputs are correct. can not adjust the hue to recover green. bulb is fairly new. ...
Unplug,replug tv and satalite box both an hour later.The tv,will reset itself,back to factory.Satalite box should upgrade it softwares.Tv now should have all it colors back.Not,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 14, 2010 | Sony KDS55A2000 55" HDTV
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Color convergance
The green hue (I had it too) is a result of the optical block failing.
Sony has extended their warranty (regardless of the purchase date). see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Apr 24, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Picture qualiry
Try adjusting the setting of "hue" control of TV.It might be the wrong setting & the ratio of red hue could be more than the required one.
Apr 08, 2008 | Sony KP-53HS10 TV
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
