Question about Sony Cyber-Shot DSC-S40 Digital Camera
Picture images The picture is prints out too dark when taken at a distance. If I use half-moon lens opening, it show the picture out of focus.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
How to shoot pictures of the moon
About this result
How to photograph the supermoon: an easy way to shoot moon ...
www.techradar.com/.../photography.../how-to-photograph-the-moon-an-easy-way-to-...
  1. Cached
4 days ago - Taking pictures of the moon is one of the more popular subjects in night photography - but it's also quite tricky to get right. Use this tried and ...
How to Photograph the Moon - Photography Life
https://photographylife.com > Photography Tutorials
  1. Cached
  2. Similar
Jun 11, 2015 - Aperture: Set your aperture to f/11. Shutter Speed: Set your shutter speed to 1/125 on cameras with base ISO 100, and to 1/250 on Nikon DSLRs with base ISO 200. Lens Focus: Set your lens to manual focus (either through a switch on the lens or on the camera) and set your focus to infinity.
How To Take Stunning Pictures Of The (Super) Moon :: Digital Photo ...
www.digital-photo-secrets.com/tip/779/how-to-take-stunning-pictures-of-the-moon/
  1. Cached
  2. Similar
Aug 7, 2014 - Start with ISO 200, f11 aperture and 1/125 second. Try a test shot. Then use trial and error by changing the shutter speed until you can find the best exposure that works for your composition without overexposing the moon. Turn off auto focus.
How-To: Photograph The Moon ' Popular Photography
www.popphoto.com/how-to-photography-moon
  1. Cached
  2. Similar
4 days ago - Planning is a big part of all photography, and shooting the moon is no ... that much money on a lens like this to take impressive moon photos.
How to shoot pictures of the moon Google Search
Nov 15, 2016 | Cameras
Why the picture is not clear when near to it
Do you mean that close-ups of objects are out of focus ? If so, this may be because you are closer than the lens's closest focusing distance.
If you mean that prints do not appear sharp, you may be suffering from camera shake, if you are using a long shutter speed, or if you are looking at a large print, or a portion of an image blown up, you may be closer than the optimum viewing distance.
Apr 23, 2016 | Cameras
THE LCD PICTURE IS CLEAR AND WHEN I PUSH THE BUTTON TO SHOT, IT STARTED TO BLURD THE PICTURE AT LCD AND PICTURE RESULT ALSO IS BLURD.
Hi chicbenzon_1 ,
The LCD picture is clear indicates that the lens is clear enough to capture the image, if there would be any disturbance on the lens you would come to know on the LCD itself.
When you push the button to shoot , it could be that you are pressing the button just half way which is a function used to focus on the object before full press of the button or actual shot of the image.
I would recommend you to half press the button till you focus on your image and then when your hands are steady and there is no shake on the camera , go ahead and press the button full which would result in the image being taken.
Hope this helps ...:)
May 11, 2011 | Olympus FE-320 Digital Camera
Sir i have purchased nikon p100 camera from croma stores belapur branch , the problem with the barrel and there were gear noise and on taking photos in dark back ground of moon there were several white...
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
Mar 15, 2017 | Nikon Cameras
Quantaray 70-300
Sounds like the aperture inside the lens is broken. You shuld send it in for service.
Aug 07, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Pictures turning out dark, LCD not adjusting
CCD sensor problems usually present themselves as either a blank image, purple cast, or lines through the image. Incorrect exposures are usually a result of the lens shutter failing to open and close correctly. Typically, the lens is not servicable and they need to be replaced.
Apr 13, 2009 | Canon PowerShot A95 Digital Camera
My d40 has a image in viewfinder, will not take picture.
What lens are you using with the D40? Is it an AF-S lens? And is the Mirror Lockup on? Chech the Custom Settings menu. If mirror lockup is on, turn it off.
Feb 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Focus
Your problem could be caused by one of several things. The lens may be out of adjustment or have a loose mount. The camera also had problems with the mirror hinges. Look into the mirror area with the lens off to see if the mirror is square within the mount ring.
Oct 09, 2007 | Nikon N2000 35mm SLR Camera
Very long shutter release delay
This is weird, usually shutter delays are caused because camera is trying to focus first, it really shouldn't happen after pre-focus. do you have a manual focus mode? if you do, try it and see if it works. if you dont, I would still suspect it some kind of focusing problem, but unfortunalty i have no idea how you can fix it yourself.
Mar 10, 2006 | Canon EOS-20D Digital Camera with 17-85mm...
Focusing distance in macro mode
On a D-565 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
