Cars & Trucks Logo
s
sammy louden Posted on Feb 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant find freeze plug on 2000 nissan altima
I can not find the freeze plug on my 2000 Nissan Altima I have took the oil filter off and above it is a hole Im not for sure if it is where the freeze plug goes or not
Thomas Perkins
Level 3:
  • Nissan Master 15,088 Answers
  • Posted on Feb 08, 2014
Thomas Perkins
Nissan Master
Level 3:
Answers
15088
Questions
0
Helped
3384476
Points
54869
It is and check under the exhaust manifold for other one.
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Nov 04, 2008
SOURCE: Location of oil filter on Nissan Altima 2005
The oil filter is located behind the right (passenger) inner fender cover. It is right next to the crankshaft pulley at the bottom of the front of the engine facing toward the right front wheel. I do not have a picture at this time.
Hope this is helpful!
Nissan Scope Technician- 10+ years experience in Nissan dealership.
Anonymous
  • 5158 Answers
  • Posted on Jan 18, 2009
SOURCE: type of motor oil for a v4 2002 nissan altima
Should be in your owners manual... but generally 10W30 will do
Anonymous
  • Posted on Feb 05, 2009
SOURCE: changing headlamp for 2000 nissan altima
I just replaced the driver's side headlamp on my 2000 nissan altima. The manual advises you to take it to a dealer or details a long process which involves removing the bumper protector -- none of this is necessary. I am not mechanically inclined and a coworker and I did it on a lunch break. Here's how:
1) Disconnect the battery by loosening the nuts that attach both the positive & negative contacts.
2) Once loose, slide off the contacts. At the base of the battery (closest to front of the car) there will be another nut that you'll need to remove (this loosens a clip which holds the battery in place)
3) Once loosened, lift out the battery which will enable you to see the headlamp connection.
4) There is a white plastic ring that attaches to the headlamp connection. Twist this to the left (about a quarter turn).
5) Once you have loosened the white ring, you should be able to gently pull out the headlamp assembly.
6) Remove the headlamp from the socket by pushing on the plastic arm which will release the lamp from the socket (sounds confusing, but once you have the piece in your hand it will make sense)
7) Insert the new lamp into the socket & slide assembly back into the hole. Note. There is a groove in the assembly which will align with a notch in the headlamp frame...you can see this by looking through from the front of the headlight cover on the outside of the car.
8) Replace the white ring and twist to the right to secure in place.
9) Replace the battery & bolt you remove.
10) Replace the positive & negative connectors (hint: don't forget to replace the plastic battery cover before you attach the connectors).
Hope this helps...let me know how you make out.
Anonymous
  • 8 Answers
  • Posted on Jun 16, 2009
SOURCE: Nissan Altima 2000 - Engine oil leaking problem.
replace the front oil seal. first i would clean the engine with purple power (degrease etc.) then look at the engine and make sure the leak is not coming from above like possibly the valve cover gasket or from the oil sending unit. try to tighten the bolts on the valve cover and even the oil pan. you never know, you may get lucky. i don't know where you are but front seals are cheap but the labor on the job is what costs you.
Anonymous
  • Posted on Aug 22, 2009
SOURCE: Hows to reset oil light and oil filter light on 2007 nissan altmi
maintenace and oil filter. i got an oil change last month on my 2007 nissan altima and they did not reset the mileage so the lgiht on the leyboard came on and I cant fix it
Replaced the fuel pump and filter on a 2000 Nissan Altona it's shooting fuel from the pump but not near the filter what can cause this
Nissan fuel pump recall : Nissan Altima Common Engine ...
repairpal.com > Problems > Nissan > Altima
Nissan issued a recall on the fuel pump for premature failure. ... I am in need of a newfuel pump and scared to drive my car and its leaking ... pump and fuel filter located and how can i access them if i wan to replace th. ... 2000 Nissan Altima.
Fuel pump and fuel filter - 2003 Nissan Altima - RepairPal
repairpal.com > Questions > Nissan > Altima > 2003 Nissan Altima
Mar 25, 2009 - Where is the fuel pump and fuel filter located and how can i access them if i wan to replace them?
Fuel Pump Replacement Cost for Nissan Altima - RepairPal ...
How To Replace Fuel Filter on Nissan Altima 2001 - YouTube? 6:46https://www.youtube.com/watch?v=Vwg2wm13ilMOct 25, 2011 - Uploaded by roluardoHow To Replace Fuel Filter on Nissan Altima 2001 ... How toreplace a 2002 Nissan 3.5 Maxima Fuel Filter 2000-2004 pt 1 - Duration: 14:20.fuel hose replacement. Car fuel leakage. fuel pump ...? 5:30https://www.youtube.com/watch?v=BPGaxxkK71cApr 4, 2014 - Uploaded by LearningZoneHere I am going to illustrate the fuel hoses (fuel lines)replacement for Nissan Sentra ... Fuel pump leak fix - quick and cheap - Duration: 11:16.
2helpful
Knock Sensor (Nissan Altima 2000 GXE picture of where it is located.
it is very simple. if you lay down underneath the car and look up at the oil filter it is just above the oil filter. you should be able to get it out with a 12mm wrench.
Oil light on nissan altima (2000) after oil change in addition since oil change noise comes for engine and check engine light on
I HAD THE SAME PROBLEM & IT WAS 2 MUCH OIL ,I TOOK A 4th of A QUART OF & EVERYTHING WENT BACK 2 NORMAL.
1helpful
Need to know where fuel filter is located on my 2003 nissan altima
It has a filter in the gas tank like a strainer on the fuel pump.It should be serviced every 110,000 miles did you know it also has no transmission filter either, that you only drain and replace oil cant take the pan off its right above frame rail.
7helpful
2answers
Where is fuel pump relay in 2000 nissan altima
It's located in the fuse box under your hood. Should be near the fender wall or the firewall
7helpful
8helpful
2answers
press accelerator pedal three times and then turn on ignition. If that doesn't work press accelerator pedal 2 times and turn on ignition.
12helpful
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
