Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I think its fried....
My scandisk 2.0 gb flashes and doesnt seem to work..If its fried ...Is there a way to retrieve my files(very important)pls say YES..?
  • bronco_chick Dec 03, 2007
    my sandisk flashes like it is about to come on then it never does. if the thing was fried it wouldn't flash. how do i get it to work?
    Habit-Forming:
  • 188 Answers
Sorry man i think u have lost u r imp data
again properly connect u r flash devise.............if it works..u will be lucky man.
best regards & best of luck..
Posted on Oct 26, 2007
I am constantly receiving this message with a micro 2 GB cruzer, "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off. To eject a disk, select...
I have just experienced this problem with e 32Gb ScanDisk card. Every 40 seconds it dismounts with "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off." and the automatically remounts itself.
The card was formatted in my Canon camera and works fine, I also can read the files with iPhoto from the camera, however with a LogiLink card reader it has the above described problem on my MacBoook Pro with MountainLion OS.
Its about time Apple that you researched and found a solution!!!!
Hans Steller
Jul 04, 2012 | SanDisk Cruzer Sdcz36-002g-b35 2 Gb Flash...
My 4 gb usb flash drive is not working (not formatting) .it showing 8 mb size when i try to format
That message normallymeans your flash drive has failed or the files structure cannot be read byWindows.
You can try it on another computer, and see if it works.
Re-formatting may restore the file structure so it can be used again, but youwill loose the data on the flash drive.
IF!!! you do have to format and that works you can use a file recovery programlike recuva
HERE: http://www.filehippo.com/download_recuva...to hopefully retrieve the lost files.
b> OR THINK YOUR COMPUTER VIRUSAFFECTED .TRY TO BE SURE FOLLOW THESE IF CAN NOT SHOWHIDDEN FILE (TOOLS >FOLDER OPTION >VIEW> CHECK ON SHOW HIDDENFILE>CHECK OFF HIDE PROTECTED AND CHECK OFF HIDE EXTENSION)
RUN >TYPE> MSCONFIG > ENTER =CAN NOT OPEN MS CONFIG)
RUN > TYPE> REGEDIT>ENTER =CAN NOT OPEN REGISTRY
RUN > TYPE >GPEDIT.MSC> ENTER =CAN NOT OPEN GROUP EDIT POLICY
THINK VIRUS AFFECTED YOURPC YOU SHOULD DELETE PARTITION AND CREATE NEW LY AND FORMATYOUR PC NOW INSTALL FRESH OS b> HOPE IT SOLVE YOUR PROBLEM
Dec 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My cruzer 1.o gb flash drive when pluged into the computer doesnt load and the light doesn't even *** on
Looks like the flash drive is dead. Try plugging into a different USB port and also a different computer. IF all these didn't work, the drive is dead. Thanks.
Nov 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
ScanDisk 4 Gb flash drive not responnding
try connecting it t different computers. if it reacts the same. well im sorry i think your 4gb sandisk flashdrive is damaged. and im sorry to tell you if that so, there is no way u can get your files back.
Aug 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How can i retrieve all my other files on my memory card?
you will need to do DATA RECOVERY and you will need special software to do it.
you might try photorec
the card has likely been damaged
Aug 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
External Hard drive wont show files or name
Even though you may hear the motor turning in your external drive the drive may not be able to read the information on the platter(s) because the arm isn't working. This cannot be fixed; you'll have to buy another external drive.
There are services that can retrieve the data on the broken drive. Google "data recovery services" and prepare to spend big bucks.
Jul 09, 2009 | Western Digital Passport WDXML800UE...
Locked Flash Drive
hi, can i anwer this.... pls try using your scandisk again and right click on it then go to properties... inside the properties of your disk you can see a three options you can see there: general, and the two others... just explore on it...
or... if the files inside your disk is not very important / or even it is important as long as you have some back up copy of the said files... all you have to do is... right click you disk and find " format "... you have to reformat your disk in order for you to use it again... thank you very much...
Jul 06, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Transcend USB decreasing memory
It seems that some space in your flash drive has been corrupted..So u can't get back full 2 GB after formatting..
Jan 28, 2009 | Computers & Internet
I hve PNY 4 gb abd have stored lot of pictures but i could not reterive the data pls help me that all very very imp data
I had the same problem once upon a time with a PNY CF card about 4years ago after I photographed an entire football game for an article Iwas doing. Everything I did kept telling me that the card was corruptedand I never could retrieve the photos. Someone told me to use a better card so I have never used a PNY cardagain and consequently have never had the problem again. Stay with SanDisk Extreme or whatever high end card you can find and you'll be much happier.
I know this is the "Close-the-barn-door" approach to not losing thehorses after they have already escaped but I have a possible solutionto rescuing your photos trapped on the card if nothing else works. Lookfor a card retrieval program on the internet. There are free ones andthere are pay ones. Free is worth nothing and the others are worth morebut start with free if you can find one. The one I used was atcardrecovery.com (which wasn't free) and supposedly can even pull photosfrom damaged cards as well. I accidentally formatted a card beforegetting the photos off and the program retrieved all of those plus manyothers that were previuosly on it, all 39,000 of them, and it was onlya 4 GB card on a 8 MB camera! I think it was around $60 for the pay version but it justdepends on how valuable your photos are to you on that card. If yourinterested here's the link:
http://www.cardrecovery.com/?rid=google&kid=cr0102
There is a free trial download offered but I don't know how many photos you have on the card so it may not get them all off.
GoodLuck-Steve A.
Dec 27, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Stopped working COMPLETELY!!!!
Had same problem.
I wiggled back and forth the part that goes into the USB port and the drive was recognized and I could copy my files onto my hard drive.
I had this problem with a different make USB flash drive and used the same procedure to get the files back.
I think that some connection inside the flash drive works loose after a while.
I am not going to trust these drives for files storage, but only to transfer files.
Jul 27, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
138 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Alun Cox
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
