Question about Philips 20MF605T Television
Philips 20MF605T I have a Philips 20MF605T that powers up but no picture and you can hear sound and can change the channel,but I have white lines rolling from top to bottom.
5 Suggested Answers
  • 4 Answers
SOURCE: vertical white line
Dont touch it just keep it running. one of the days you wake up and it will vanish just as it appeared without cause. This is because it has happened to me once with my Philips 42. the don
Posted on Aug 10, 2007
  • 129 Answers
SOURCE: rolling white lines on the screen
Posted on May 17, 2008
  • 8 Answers
SOURCE: Red & Green lines rolling from the bottom to the top
You could have a ground loop problem. To test plug DVR and TV into same outlet.
Posted on Apr 30, 2010
  • 2098 Answers
SOURCE: Our Philips 42PF7320 42 in.
Your unit is a Plasma TV, it hasn't a bulb.
The symptoms you've described is caused by faulty upper Y-scan drive. It is a rectangular board located at the left side of your unit(if you are facing at the back panel). You have to replace this board to resolve the issue.
You can do it yourself because no soldering required, let the unit unplug from the outlet for 1 hour to drain the voltage from the power supply before you replace the board. Pull-out the connectors from the existing board, put-in the new board, re-insert the connectors and you're done.
I would advice you to check the actual part no. of your board that is printed on the white sticker on the board itself to get the right replacement online. Click the link above to see how it gonna looks like...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Sep 20, 2011
  • 37 Answers
SOURCE: I have a philips 42pf9431d/37 and I have black and green lines on the right side of the tv what is the repair for this
Sorry, unless you know tv's nothing you can do and the fix is very expensive. Basically not worth it
Hope you have warranty and take it back
It is fairly common to have few "dead" pixels that are not obvious
I know this is not the answer you are looking for but all new electronics are made in such a way that it is usually not worth the trouble
After all this is why they try to sell you extended warranty and if you pass you are stuck and have to buy new
Posted on Feb 06, 2012
0 characters
1 Points
Philips plasma TV Model number 42PF7321D/37 with green led light ON but no picture.
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 08, 2016 | Philips Flat Panel Televisions
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Flat Panel Televisions
No picture (white screen)...
its a video cable or LCD connectors. remove and re-connect again.
May 27, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Tv philips 20mf605t no power
write down the number of the micon if that is the component that you are suspecting and go online checking for company from who you can purchase the such company is and
Aug 29, 2008 | Philips 20MF605T Television
Phillips 42pf9630a 42 in
A code 7 is related to a hardware problem that reqiures service.
If you want to get a referal to a Philips authorized service center call 888-744-5477 and they can prive contact info for a servicer in your area.
Aug 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Samsung Syncmaster 741MP
Similar problem was solved by transporting the wrong TV some tens of kilemeters by a car :-) Maybe there was some junction error inside, or a longer power-off state was needed to fix the problem?!
Sep 07, 2007 | Philips 20MF605T Television
Philips 20MF605T Television Logo
37 people viewed this question
Top Philips Flat Panel Televisions Experts
Are you a Philips Flat Panel Television Expert? Answer questions, earn points and help others
