My lcd screen broje on my note book so I order a used but decsribed as fully working off ebay
I have replaced it which was easy but nor
w when I switch on it is just a blank white screen with nothing on it at all
Where have I gone wrong in my istallation
If you are a bit handy you can order spare lcd`s and finde instructions on how to repair it your self here: http://www.ifixit.com/Guide/Repair/Installing-PowerBook-G4-Titanium-Mercury-Display/69/1
Do note, that you should have some experience in repairin laptops/electronic as this is not a easy opperation to do by you self, but its not imposible :)
Best of luck!
if you hurry you can order one off ebay its a olevia but they use the same screen 220724844497 which is an lg philips panel. Before doing that check if your backlight inverter is defective. A more common problem with this tv is blue screen from tcon board failure which is quite easy to fix.
Sorry it junk,sell it on Ebay.com for parts or save it for parts for the new purcharse tv with the same model.U can try Shopjimmy.com for some tv 32"LCD screen,but don't if they have Philip LCD or LCD work with Philip LCD tv models.But basicly LCD broken in 40 and up is not possible to get LCD screen.Tv compannies sell LCD Screen out the same as a new tv price or well exceed the price after part and labors.
The screen will probably have to be replaced. Try gently squeezing around the edge of the lcd where the line is present. Sometimes this will get it going temporarily. I have even used close pins before to keep pressure on it to keep it on. A new screen can be ordered on ebay for around $100 and are fairly easy to replace. I recommend getting the exact part number on the back of the LCD before ordering.
go to you tube look up repair for your phone they show you how to take apart your phone and go to ebay order tools and parts i fix phone all the time good luck
FIRST OF ALL TRY CONNECTING YOUR NOTEBOOK TO ANOTHER MONITOR...THIS WILL TELL IF THE LCD SCREEN IS FAULTY OR YOUR VIDEO CARD.
IF YOUR LCD SCREEN IS FAULTY AND YOU WANT TO DO IT YOURSELF
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/all-comments/
A VERY USEFUL SITE.SCREEN WOULD COME IN BETWEEN $150-200
YOU CAN CHECK AT EBAY FOR THE APPROX. PRICE,YOU CAN EVEN CALL THE HP COMPANY AND ASK FOR THE REVISED RATES THAT WILL GIVE YOU AN IDEA.
IT IS NOT THAT EASY WITH THE VIDEO CARD BECAUSE IT'S USUALLY ATTACHED TO THE MOTHERBOARD AND CONSIDER THAT YOU HAVE TO SPEND MORE BUCKS THAN THE SCREEN FOR A GOOD VIDEO CARD.
I WOULD STRONGLY RECOMMEND TO TAKE IT TO AN AUTHORIZED SERVICE CENTER.
Go on ebay and buy a new inverter for less than $10. Go on youtube to see how to replace the dell inspiron 1526 lcd inverter or the dell inspiron 1526 lcd screen. I put the lcd screen on because sometimes the problem might be your screen. If things don't work after installing the new inverter board, then buy a new lcd screen off ebay. The inverter board and screen are easy to install. Just go on youtube.com to find a video that walks you through it. The inverter sits at the bottom of the lcd screen. Some are screwed on, some are welded onto the screen, some are held by a small piece of tape. Even if you have to pry the old one off, just put the new on on held by a small piece of tape. 10results for Dell Inspiron 1526 inverter board
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
A pinkish tint is indication that the backlight tube inside the screen is not fully lit. But then it goes black - meaning the tube shut down? That part don't make much sense - it's certainly possible, though.
Replacing tubes is pretty surgical so I wouldn't recommend it. Replacing the screen should be pretty darn easy. A good, used screen should be pretty cheap on eBay, so that's where I'd start.
