Home | Gestetner | - COPIER, PRINTER, & SCANNER Copier | LANIER LD245 SHOWS FUN...
Gestetner - COPIER, PRINTER, & SCANNER Copier
Problem for Gestetner - COPIER, PRINTER, & SCANNER Copier
LANIER LD245 SHOWS FUNCTIONAL PROBLEM SC542
By carmenchu240 on Jun 06, 2009
Solution #1
posted on Oct 18, 2009
Not Rated)
socalern
Rank: Master
Rating: 82%, 2 votes
This is a fuser temperature control error code. Could be as easy as resetting the code and rebooting or it could require parts such as a thermistor, thermofuse, heat lamps. Typically though its the thermistors, the sensor that reads the temperature from the heat roller surface.
Was this helpful?
Yes
No
Solution #2
posted on Jun 09, 2009
Not Rated)
sandmanmac
Rank: Wiz
Rating: 84%, 781 votes
fuser error. problem needs to be reset in service mode after the problem is fixed
Was this helpful?
Yes
No
Popular Solutions for Gestetner - COPIER, PRINTER, &
Questions and Unsolved Problems for Gestetner - COPIER, PRINTER, &
Do you recommend Gestetner - COPIER, PRINTER, & SCANNER Copier?
Answer
Answer
My Gestetner Dsc445 shows a continuous misfeed (J001) @ Z1 after removing ALL paper &... (More)
Answer
# 756 Bsk III Stage 5 th Block 5th Cross, Bangalore - 560 085
Answer
where can i get the hp deskjet f2235 printer drivers please guide me.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gestetner - COPIER, PRINTER, &...:
Top Copier Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
