Question about Xitel MD-Port DG2 (MDPORTDG1)
Computer won't turn the device on.
Recently I plugged the DG2 in, got the red LED indicating it was connected, and easily loaded the MD player. I tried it again today, with two different DG2's and neither gave the red LED, and I could not load music. Seems like a PC problem rather than an MD-Port problem. Any ideas? OS is XP
  • crzy bird Dec 29, 2007
    wont t urn on omputer acknowledges usb use with sound but nothing else
  • Lanns80 May 21, 2008
    I have the same problem, my laptop recognizes the usb is plugged in, but won't light up the DG2. It did the first time I plugged it in but now it won't at all.
HOLA NO TENGO EL SOFTWEAR DEL MD-PORT DG2 COMO LO PUEDO BAJAR A MI PC PARA INSTALARLO.
Posted on Oct 17, 2008
MXD-D4 remote does not work
These units are often on ebay for cheap, there are several nearly identical CD->MD Recorders made by Sony, there is even a somewhat rare 5CD->MD Recorder deck.
I see these all of the time on eBay, prices vary with the seller and condition I think about $40 on the low end and up to a lot if one is mint. I recently got the 5CD>MD Deck for $25 at Goodwill since they did not know what they had. The remote control for that one is rare but also turned up a month or two later at another resale shop.
The D40 is a good unit to have since it clones CD>MD easily.
May 30, 2013 | Sony MXD-D40 Mini Disc Player
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
I have the swagger 2gb and i cant figure out to download the mp3 to my mp3 player
1. Plug the small end of the USB cable into the player. Plug the other end into an available USB.
2. The player will light up with the red flashing LED light flashing to indicate that the device is recognized and ready for data transfer.
3. Wait for the computer to recognize the player.
4. The Removable Disk auto-run window will appear on your computer.
Jan 23, 2011 | Sakar MP3 Player
Gateway mx6448 Notebook will not power on, Red LED flashes 4 times when power on button is pressed then nothing happens. It is the same with only the battery. LED will not flash if I have only the power...
There can be many things associated with no power to the computer.
  • The outlet into which the computer is plugged may be inoperative.
  • The surge protector you are using may be inoperative.
  • The power cable may be loose or damaged.
  • An internal device may be damaged.
  • The power supply may be inoperative.
Basic Troubleshooting Power to the Computer
There may not be a consistent flow of power to the computer.
  1. Verify that the outlet into which you are plugging the computer is operational.
  2. If you have the computer plugged into a surge protector, plug it directly into the outlet.
  3. Verify that the power cable is plugged securely into the back of the computer.
  4. If you have a monitor with a removable power cord, swap the power cords between the monitor and the computer.
Note: If you recently added a new hardware device prior to experiencing the no power issue, turn off the computer and remove the newly added hardware. If there is still no power, reseat all the other cards and cables in the computer to verify that all other devices are seated securely.
Resolving Power Supply Issues
  • External Device Conflicts
  • There may be an external device causing the computer not to turn on properly.
    1. Before continuing, verify your computer is turned off.
    2. After you have established that adequate electricity is going to your computer, verify that the voltage switch on the back of the power supply is set correctly. The small red switch is to be set to the 115-volt setting.
    3. Remove all external devices except the monitor and turn on the computer. If the fan on the back of the computer now spins, turn off the computer. Plug in the external devices one at a time and turn on the computer after each device is added.
    4. Note: If you removed all external components and the fan on the back of the computer does not spin, the problem is with something inside the computer.
  • Internal Device Conflicts
  • This helps determine if the issue is a damaged or badly seated component.
    1. Verify that the computer is turned off.
    2. Remove the case from the computer.
    3. Remove all the red, yellow, and black power connectors from each floppy disk drive, CD-ROM drive, and tape backup unit that is in the computer. The only devices connected to the power supply are your hard disk drive and motherboard.
    4. Turn on the computer and verify that the fan on the back of the computer spins. If it does not spin, turn off the computer.
    5. Remove the power connection from the hard disk drive and reconnect power to one floppy disk drive. Turn on the computer and verify that the fan on the back of the computer spins.
    6. Reseat the power connection from the power supply to the motherboard. Turn on the computer and verify that the fan on the back of the computer spins. If the power has been restored, turn off the computer and reconnect the power connections to the devices. Test the computer for power after reconnecting each device.
  • Power Switch
  • The power switch may not be functioning properly.
    1. You may need to open the case and readjust the power switch.
    2. Locate the control panel inside the computer and remove any screws holding it in place.
    3. Turn on the computer with the control panel removed by pressing the button on the control panel that corresponds to the power button. If the power supply fan spins and/or the computer turns on, put the control panel back in its place. Try to turn on the computer again.
  • Test Switch and Diagnostic LED
  • Note: Not all power supplies have a test switch and diagnostic LED.
    Certain power supplies have a test switch and LED to help better troubleshoot the device. The green LED is always on when the computer is powered on. If the computer is not receiving power please perform the diagnostic test below.
    3. Remove all of the red, yellow, and black power connectors from each floppy disk drive and ROM drive and the tape backup unit (TBU) that is in the computer. Remove all power connectors from the motherboard. The only device that needs to be connected to the power supply is the hard disk drive.
    4. Press and hold the test switch for five seconds on the power supply, and then verify that the green light on the power supply comes on.
    5. If the light comes on:
      1. The power supply is good and something that was plugged into the power supply is causing the computer to not turn on.
      2. Plug devices in one at a time, testing with the test switch between each device to determine what is causing the power issue.
      3. If all devices are plugged in and the light is working, the connections may have needed to be reseated, or it is possibly a power switch issue.
      4. Go to the power switch section of the power supply checklist for additional troubleshooting steps.
    6. If the light does not come on:
      1. Disconnect the power from the hard disk drive, and then plug in power to the CD-ROM drive and determine whether the light comes on.
      2. If it does, follow the preceding information - "If the light comes on."
      3. If the light still does not come on, contact Gateway Technical Support.
    7. Confirm that power from the power supply is connected to the motherboard. Remove all cards and cables from the motherboard, and press and hold the test switch for five seconds on the power supply and determine whether the green light-emitting diode (LED) comes on.
    8. If the LED comes on, put the devices back in one at a time, testing between each device to determine what is causing the issue.
Dec 02, 2010 | Gateway MX6448 Notebook
What kind of cable do I use from the MD to the computer. Mine I bought on ebay came with no such cable
250b550.jpgYou'll need a MDPORTDG2 which is an after market accessory
Item Information Direct from SONY
MDPORTDG2 PC LINK KIT
  • For digitally recording PC audio to MiniDisc
  • Optical digital signal assures high quality, distortion free recording
  • Includes MusicMatch Jukebox Plus, a software that lets you find and play internet audio (MP3) on your computer; also lets you rip and encode tracks from music CDs to create your own MP3s
  • No sound card is required; installs simply by plugging into a USB port - no need to open the computer or turn it off
  • Distortion free optical TOSLINK output and the latest studio technology provide exceptional digital audio performance
  • Kit includes MD-Port DG2 digital audio interface, USB cable, studio optical TOSLINK cable and full version of MusicMatch Jukebox Plus software
  • Compatible with Windows 98, 2000 or Me and Mac OS 9.0.4 or higher with Apple Extension; not currently compatible with Mac OSX
  • Manufactured by XITEL
  • Currently In Stock: YES
    Unit Price (in USD): $59.95
    ITEM WEBSITE
    MD-R700 SITE
    Feb 05, 2010 | Sony Walkman MZ-R700 Personal MiniDisc...
    HOW DO I UPLOAD FROM SONY MZ-R700 TO PC?
    f5335c6.jpgYou'll need a MDPORTDG2 which is an after market accessory
  • Includes MusicMatch Jukebox Plus, a software that lets you find and play internet audio (MP3) on your computer; also lets you rip and encode tracks from music CDs2_bing.gif to create your own MP3s
  • No sound card is required; installs simply by plugging into a USB port2_bing.gif - no need to open the computer or turn it off
    ITEM WEBSITE
    Dec 14, 2009 | Sony Walkman MZ-R700 Personal MiniDisc...
    Power light on& status light on
    The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
    Apr 29, 2009 | Computers & Internet
    Sony net md mz-n707 problem
    Ive used minidiscs for a long time an really worked for a minidisc computer solution. However Sony really commited suicide as far as limiting the format to non-computer usage. They've dont this on purpose, and its really led to flash players domination.
    As far as a solution.. The only viable possibility is to get a usb sound card with an optical in. They can easily be found for $20. Then you can get flawless transfer from MD to PC. Only downside is that its limited to real time recording. But thats the best that is available for the time being outside the Sony software itself.
    Dec 09, 2008 | Sony Net MD Walkman MZ-N707 Recorder
    HOW DO I UP LOAD FROM Sony Hi-MD Walkman ON MY COMPUTER
    try media player, if you open media player and nothing happens, press f5, it should recognize your device
    Jul 05, 2008 | Sony Hi-MD Walkman MZ-DH10P Personal...
    Televison & Video Logo
    254 people viewed this question
    Top Xitel Televison & Video Experts
    Marvin
    Marvin
    Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
