Question about Samsung DLP HL-P5663W 56" TV
Loud noise I hear a loud noise coming from the back of my tv. I believe it is either the color wheel or one of the fans. The picture doesn't come on anymore. I also see all the lights on the front flashing. I think also the bulb is toast because of the other problem
  • Anonymous Dec 03, 2007
    same problem, high pitch whirring sound, is the color wheel something i can replace myself or do i have to take it to a technician?
Our samsung's bulb needed to be replaced indicated by those front flashing lights
Posted on Nov 11, 2007
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
TV will not come on. Tries to start, no pic, then shuts itself off. Humming sound like fan runs for a while and then stops.
This tv have a colors wheel is dead,require a new colors wheel replacement.Tv humming,loud squiling or motor noises and picture flashes black&white within the picture.The problems is the colors wheel are worn out or warp and it not spinning correctly in it motor joints anymore,it is the tv causes.Call the tv repair shop for a tech. to repair and replacement of the colors wheel.This job,it not simple,must take out alots of machanicals parts,even come to the colors wheel itself to replace it.
Nov 26, 2010 | Samsung HL-S4266W 42" HDTV
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Model 5063W - loud noise
The picture is pink, that would point more toward the color wheel, and you can see the fan through the vents in the back and you can go from there. It sounds more like the color wheel since you have a picture malfunction.
Jun 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Screen shows only black and white
Color wheels do go bad quite frequently, if you got 5 years out of the original, believe me, that's good.
The color wheel is attached be a bearing, like a fan and when the bearing starts to ware out the color wheel on the shaft starts to wobble and that's what you hear, they spin I believe around 3000rpm. Try contacting your servicer again, don't be mad, maybe he'll be kind enough just to charge you for the color wheel. I'm sorry, but that's the best advice I can give you..Good Luck...
Feb 17, 2009 | Samsung HLN507 50" Rear Projection...
50" Samsung dlp rear projection hdtv
More than likely its the color wheel there is a bulletin from samsung indicating that a loud buzzing is often related to the color wheel.Let me know if you need to know where to get a color wheel and I will post a link, just include your full model number.
Apr 14, 2008 | Televison & Video
Samsung DLP HL-P5663W 56" TV Logo
172 people viewed this question
Jerry Greenberg
Jerry Greenberg
