Question about Kenwood eXcelon KDC-X879 CD Player
Toc error when every i try to play a cd i get a toc error on my screen
  • 1 more comment
  • LENNA VAUGHN Aug 13, 2013
    how can i fix it ?
  • Anonymous Mar 18, 2014
    my Kenwood KDC X 494 keeps reading TOC error when I try to play my CD why is it doing this please help
    President:
  • 624 Answers
I have repaired many of these cd players working at an authorized Kenwood service center for over 17 years.
There are only 2 things you can do as the end user of this unit.
1. Try cleaning the disc's. If the cd has any fingerprints or scratches on the inner most part of the cd, the laser will not be able to read the TOC. It is the first thing the cd player tries to do and if that fails for any reason, the disc can not be played at all.
You can purchase a disc cleaning kit, or you can do what I do. I spray a small amount of windex on the data side of the disc and then clean it with a soft cloth like a bath towel or terry cloth. This works as good or better than the cleaning kits and is much cheaper.
If that does not work you can go to the next step.
2.. Clean the lens of the laser with a cd cleaning disc. They can be purchased at many stores that sell cd players and music cd's.
You put it in the player and let it run about 20 to 30 seconds and then you eject it.
If neither of these things help, you most likely have a bad laser pick up. You will need to take it to an authorized Kenwood service center and you can count on the repair being anywhere from $120 to $175. Depending on the rates and the mark-up of the laser pick up.
This is a very good car stereo, and is probably worth the repair cost, but it does have a 2 year warranty. It is not too old, so it may still be under warranty. If so, the repair is free for you.
I hope this helps you with this problem, and if so, a good rating is always appreciated.
Let me know if you have any other questions about it.
Posted on Jun 22, 2008
  • derekgharris Dec 13, 2010
    what if this only happens with one particular disc?
  • Spencer Frasher May 08, 2019
    If it's only one disc, then the disc is at fault. Look for fingerprints and scratches on the disc.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
TOC = table of contents. It means that the unit cannot read the disc. Probably a dirty lens. Get a lens cleaning disc at Walmart and run it through. Even if it doesn't fix this problem, it is a good idea to use it periodically anyway, and they work on all CD players.
Posted on May 08, 2019
Yes the toc error what does that mean
Posted on Apr 17, 2009
3 Suggested Answers
SOURCE:
simplemitch
  • 752 Answers
SOURCE: TOC Error
Burned ones? Or do "real" CDs do it, too? If ALL do, then the laser was damaged or misalligned and will have to be serviced.
Posted on Sep 22, 2007
hawkwatcher
  • 67 Answers
SOURCE: TOC ERR for kenwood cd player
Most likely optical pickup is defective. I may be able to get a pdf service manual if you wanted to try repairing yourself kstahl65@att.net
Posted on Jan 27, 2008
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
Cd wont play after finalize an toc error C14 appears
You can visit this link to check it this error out.
toc error C14
Best regards.
May 26, 2009 | Sony RCD-W500C 5-Disc CD Recorder
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Kenwood eXcelon KDC-X469
toc error is a table of contents error on cd not unit, laser pickup may be damaged
Oct 28, 2008 | Car Audio & Video
TOC ERROR
mine too can anyone help?what did u do
Sep 19, 2008 | Kenwood KDC-MPV622 CD Player
E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Feb 25, 2008 | Kenwood KDC-MP205 CD Player
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
TOC Error
Sep 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Kenwood eXcelon KDC-X879 CD Player Logo
8,982 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
