I have a raypak heater. when i turn it on it heats up and soon after it starts to shake and it shows error code HL1. i suspect its overheating but not sure why.
This issue sounds tricky. I recommend you callthe Raypak technical support at 800-947-2975 or 800-627-2975 and they should beable to help you figure this issue out.
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com BD1 Board failure EEP Microprocessor error FAN Blower pressure failure FFL Flame sensing when pilot and gas valves are closed GVC Gas valve closed GVO Gas valve open HL1 High limit switch #1 open HL2 High limit switch #2 open IGN Ignition failure ILO Ignition lockout - Propane units only PRS Water pressure switch open ROL Heat roll-out safety switch open SNS Sensor failure, Water temp. below 36°F or above 110°F VNT Vent switch open
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
