Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant adjust foot tension on minn kota edge - Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor
Mike Marcotte
Level 2:
  • Expert 76 Answers
  • Posted on Sep 26, 2009
Mike Marcotte
Expert
Level 2:
Answers
76
Questions
0
Helped
45505
Points
120
Hi!
Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
Here's a schematic:
Edga 40
Best of luck!
Mike
1helpful
I have lost speeds 1 thru 4 on a minn kota edge 70. 5 still works fine where should i start troubleshooting
Hello Richard,
It has been some time since I have been around trolling motors but it sounds if the variable speed sensor or switch is either corroded or burnt out. Since you had the speeds and they are slowly disappearing it sounds if the switch is failing. If you are somewhat mechanical and know how to test using a volt ohmn meter you can check the switch this way to see if it is the switch. If the switch tests fine then your circuit board in the motor head or foot pedal has gone bad.
Hope this helps some
How are adjustments made to make the steering less sensitive ?
On the front side of the foot pedal is a large Phillips head screw. Tighten a little. It puts more pressure on the cable. Don't turn more than 1/4 turn at a time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
1helpful
Broken plastic on minn kota steering cable
Hi!
Here's a schematic:
Edge 40
My guess is you need key# 80 (part# 2232360 cable drum pulley)
Good luck in your repair!
Mike
On high speed the motor turns way too easy and is uncontrollable.Dont have instruction book so not sure how to tighten up the tension
Hi!
Here's a schematic for your motor:
Edge 40
My guess is the cable needs tensioning.
Flip over the foot pedal and tighten key #125 a bit, then try it out again.
Mike
TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
Hi!
Here's a schematic:
Max 74 Bowmount
Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
Best of luck
Mike
4helpful
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
