All i get after reseting my TV to factory defaults is a blue screen with the "DTV" label on the top left corner. No menu botton works (build in nor remote control) and i cant switch it to analogic either. DVD and Cable are not showing on the screen either. So im stuck there.
I tried umplugging all cables, and testing plugging them back one at a time, to no avail.
According to to the user manual, a configuration menu should show automatically after reseting the TV to factory defaults, but that didn't happen either.
Any help will be appreciated. Thanks
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
I've also experienced the same problem. I got analogue TV pictures immediately after switching the TV on for the first time, but after trying and failing to get a menu for the Digital tuner, pressed the Menu button on the side of the TV. After that all I get is the same blue screen with DTV in the top left corner. I cannot now get any of the menus to work or switch back to Analogue only TV. Can anyone help?
I have the same problem.
I have done the hard reset but it is still blank. I have read somewhere that i should now disconnect it and wait till morning. will this work?
I have the same problem too
