Question about Texas Instruments TI-85 Calculator
TI-85 Display Has Missing Lines
I've had my TI-85 for a while, but recently, a few horizontal lines on the LCD display grid do not light up. This makes reading the display difficult. Does anyone know what might be the cause of this problem, or better yet, how to attempt a fix? Thanks.
  • 1 more comment
  • ymiverson Nov 02, 2008
    Thought that maybe it just needed new batteries, but even after fresh batteries there are several missing horizontal lines on the display screen that make it hard to read.
  • tonyr76 Nov 28, 2008
    I have the same problem. But Instead of missing lines, it's a black or dark grey spot that didn't leave me see what's on display. How can I fix it?
  • Anonymous Jan 08, 2009
    same problem here, interestingly so that i have had this calculator since '93 and just recently i am finding others havingthis exact problem...design issue?
    I think, though, the next step is to try to find the sam lcd or similar from jameco, or other supplier.
Have u ever modded it? it can (and probably will)damage the screen (graphics driver)
Posted on Jan 24, 2008
Horizontal lines have appeared on the screen what has caused this and can I get rid of the lines.
The LCD in the viewfinder likely has connection problems or broken circuits. Did you drop it recently? Was it subject to extreme temperature etc recently? You may find the lines shift around or even go away for some time. That would imply bad connections. If your technical enough to disassemble it, there is often a rubberised connector use between the LCD and circuit board that can be cleaned. It's delicate work tho.
May 08, 2016 | Nikon COOLPIX S52 Digital Camera
How do I get rid of grid lines on my Asus computer monitor? I have had it less than one year.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screen-shots to defective LCD panels are given. You can see and compare to that to your device, and can make sure about the fault to an extent.
Oct 08, 2015 | ASUS Televison & Video
I can not get the horizontal lines to appear on my graph. I have turned the grid on but only the vertical lines show up.
Open the Window configuration utility and change the value of the Yscl parameter. It may be too large for the range of the function you are displaying (Ymin to Ymax)
Aug 12, 2014 | Texas Instruments TI-83 Plus Calculator
My camera has lines running through the screen. Did I break something?
Probably not, many digital cameras have the option to display grid lines on the display to make it easier to frame your pictures. Look in your camera manual to see if you can turn grid lines on or off.
Grid lines can help you frame horizontal pictures (like a landscape).
Hope that helps!
Feb 22, 2011 | Nikon Cameras
TI-82 display isn't fully working
This happens alot with calculators that have been in storage for a while, you can fix this by taking the batteries out and let it sit overnight.
May 05, 2009 | Texas Instruments TI-82 Calculator
Some lines on the screen are missing
tere are problems with your´s calculator display you need to take apart screws and carefull apart display, and then clean with isopropilic alcohol, arm display again and probe befor cover them, it´s ok close the cover if not repeat till the problem was solved
Jul 19, 2008 | Texas Instruments TI-85 Calculator
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Texas Instruments TI-85 Calculator Logo
1,009 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
