Question about RCA D52W19 52" Rear Projection Television
POWERS OFF BY ITS SELF
TRY TO TURN TV ON , GREEN LIGHT COME ON FOR A FEW SEC, THEN POWERS OFF, THEN IT SMELLS LIKE BURNING WIRES OR SOMETHING . WHAT COULD THIS BE? WOULD IT COST TO MUCH TO FIX?
  • 1 more comment
  • cudock Oct 29, 2007
    thanks, not real good with elec, how hard would it be to replace it?
  • Anonymous Nov 26, 2007
    my tv does the same thing the green light turns on for a few seconds then turns off,mine does not smell any burning,but it never turns on.i am going to contact a technition to solve the problem,it seems i am not the only one having problems with this product. so sad!
  • kdknows Dec 02, 2007
    tv would go off and on by its self. now green power light stays onn few seconds an d goes off, tv not working
    Problem Solver:
  • 13 Answers
He most likely have a whole in your high voltage flyback transformer.Ref #LL008 if the transformer has a silver face then the part # 269296. if not part # 270125
Posted on Oct 29, 2007
My sony kdl 46 turn on tv green light for few sec then stnby light flashes 2 times , what does that mean
I checked on the schematic, there is a self diagnostic mode for the tv accessed with the remote control. If the TV does not turn on I would highly recommend finding a local reputable service facility as this might be completely a fault inside the TV. https://www.encompassparts.com/shop/model_research_docs/?file=/SON/sm/KDL46V4100.pdf
Please check page 12 for self diagnostic procedure.
Apr 18, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
HD56W66 powers on screen flashes foe a few sec.
On your Deflection board Look for Bad capacitors CP150 2200uf 16v CP114 CP120 in same circuit they will be puffed up on top if they are replace all 3 capacitors.other 2 are 220uf 35v and 330uf 35v
Mar 17, 2010 | RCA HD56W66 56" HDTV
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ws65909 powers off about 3 sec after power on
a code will always read 12-normal if you just plugged the tv in. it has to try to turn on then shut itself down to log a code. Or shutdown is caused by something the tv cannot detect . Or a front panel button has failed- does the green light turn on for a second when you hit the power button on the remote? if not try unplugging the front keypad behind the speaker cover.
Oct 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Bad picture around the edge
Hii...
I'm not quietly sure...but sounds like you have much bad caps...I'll try to find out more...
Thank's
[Vrya]
Mar 04, 2008 | RCA F36650 36" TV
Powering on
needs a new flyback
Jan 01, 2008 | RCA HD52W58 52" TV
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
