HP 4570C Flatbed Scanner Logo
A
Anonymous Posted on Feb 06, 2014
Scanjet 4570c not working on OSX 10.7.5
2 Related Answers
A
Anonymous
  • Posted on Jun 20, 2008
SOURCE: editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Computer Links
  • 2386 Answers
  • Posted on Dec 14, 2010
SOURCE: Loaded HP Scanjet 4570c software correctly but
Hello
Re-installation of drivers is recommended, if disk is giving problem do download from the HP web site and install
Good luck
Driver for hp scanjet 4850 osx 10.9
It looks like the HP scanjet 4850 is not supported by 10.9, There is a kind of work round listed at http://h30499.www3.hp.com/t5/Macintosh-Compatible-Products/OSX-10-9-MAVERICK/td-p/6246535#.UuGPVvbFLpS search for 4850 it is right at the bottom of the page Hope this helps.
Also look at https://discussions.apple.com/thread/5804111
Hp scanjet 4570c + windows 7
Download Windows Vista version (32 bit or 64 bit) depending on your Windows 7/8.0/8.1 (32 bit or 64 bit) from: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=77368&lc=en&cc=us&dlc=en&lang=en&cc=us
Then, extract the file that you download "setup_basic_4500_500.exe" using WinRAR to Desktop.
Next, go to Control Panel then Device Manager. You will see the scanner "hp" under Other devices with error. Right click on it then select update driver software. Select Browse my computer for driver software. Click Browse and point it to the folder on your desktop that contains extracted files. You can make sure to check on include subfolders.
That will install the driver perfectly fine under windows 8.1 in my case 64 bit.
Trying to connect to an HP Scanjet 4570c to a Dell Inspiron 1750 notebook computer. When I connected the USB cable, it said it updated some drivers, but there is no icon on the laptop to scan, and when I...
If you are under Windows 7 , it's because HP doesn't produce anymore drivers for your unit beyond VISTA .
Download the latest driver available from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=77368&
and try running your scanner with it . If you don't succeed , try in compatibility mode .
If it still doesn't work please don't blame me , blame HP .
Best regards .
My HP scanner stopped working. THe light appears
Not worth fixing. The bulb is wearing out and you can't buy them.
6helpful
HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
Scanjet 4570c lamp not lighting
Contact HP for warranty services, if it's still new and covered.
You will likely get a replacement unit or factory refurbished replacement.
If out of warranty you will likely have to buy a new one.
Hi, My HP 4570C scanjet has an intermittent problem - during scans, the light bar will stop/jam at an arbitrary spot in the cycle. My guess is that the problem may indicate the need for lubrication on a...
Posted by Lonu Feruz,
I have HP scanjet but unfortunately i dont have the driver CD and it is not written anywhere to show HP scan model except this number C7710A. Which driver works on type of scanjet using windows XP
Editing text
Windows
Macintosh
k24674
Grand Canyon Tech
Grand Canyon Tech
