Question about JC Whitney - Dual Blue Led Speakers Car Speaker
Dual SBX554 I just got a set of Dual Illuminite SBX554 speakers. How do I connect the power to my car battery?
  • 1 more comment
  • DaMonkey999 Jan 29, 2008
    The speaker's LEDs need a 12v power source...
    The speaker [on the back] has a 2 pairs of negatives and positives. One set is for the sound, which isnt the problem. The problem is the other two, which is the 12v power source...
  • Anonymous Mar 11, 2009
    idk how to, or where to put the wires through for the led lights.
    New Friend:
  • 101 Answers
POWR TO BATTERY FOR WHAT?DOES THE SPEAKERS HAVE AN AMPLIFIER? NEW RADIO? SPEAKERS ALONE ARE NOT CONNECTED TO BATTERY ,UNLESS THEY ARE POWERED SPEAKERS,USALLY SUB-WOOFERS HAVE THEIR OWN AMP.iF YOU ARE CONNECTING A AMPLIFIER START WITH A FUSE SAME SIZE AS THE AMP,CONECT 1ST TO THE BATTERYTHE TO THE FUSE RUN A SIFICIANT GAUGE POWER CABLE TO THE AMP.GET THE GOUND FROM A PART OF THE CHASSIS CLOSE TO THE AMP,ALSO SAME SIZE OR LAGER GAUGE WIRE.THEN YOU HAVE TO RUN A REMOTE SWICH WIRE FROM THE BACK OF THE RADIO TO THE AMP.iF RADIO DONT HAVE REMOTE ,CUT INTO THE POWER ANTENNA WIRE .RUIN YOU RCA CABLES TO THE AMP AND WIRE YOU R SPEAKERSMbUT FIRST DISCONNECT YOUR GROUND FROM THE BATERY MOST IMPORTANT.ANY '?'S.WRITE BACK RATING PLEAse.
Posted on Jan 29, 2008
  • 4 more comments
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 29, 2008
    http://www.dualav.com/speakers/sbx.html
    you can get the manual from here if you need more help get back to me . rating please
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 01, 2008
    to find out which is the power leads .tyake a battery with a wire and touch 1 set of terminals if you hear a sond those are your speaker terminal.the other 2 are for the lights on the speaker.which i think is ridculous..By the way I tried to get some input ,wasn't familar with those speaker,took time to do some research ,came up with the manual for the spealers and you give me an inappropriate rating?change it or next time your on your own
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 03, 2008
    get ground from any metal close to speaker .run a wire from speakr to battery or fuse box for positive ,make sure u put a in line fuse.
  • chris ZAMBROTTA
    get ground from any metal close to speaker .run a wire from speakr to battery or fuse box for positive ,make sure u put a in line fuse.change rating please
  • chris ZAMBROTTA
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 04, 2008
    did that help if so can u remove those 2 inappropriate ratings.How many others tried to help .at least i looked into it.that wasn't nice .you don't burn people when they try to help you.you might find yourself all alone next time.
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
I have the dual xdv8125 car stereo and i hook all the wires up but nothn comes on. its hooked upto a 12volt dc power converter box. it wont do nothing at all.
Make sure that the DC has more than 3/5Amps rating with good DC to make the set working. Test with a car battery to confirm your connection if not check the speaker connections, the main power, switched power and ground must be in order.
Aug 28, 2010 | Dual XDV8125
I need a wiring diagram to hook up a set of dual illuminite speakers in my car
Check out www.The12volt.com
They have all kinds of wiring diagrams. Be careful.... Car systems are designed to handle certain number of speakers and resistance (ohms). Hooking up more speakers without the proper amplifiers can damage your cars radio.
Sep 20, 2009 | Dual XNP653 3-Way illumiNITE Speakers Car...
How to connect the 12 volt DC to the illumination lights from the tweeter
1) light have 2 wire R./B.
take R n connet with other B .n 2 wire r there two join too dc okk/............
Sep 07, 2009 | Dual XNP653 3-Way illumiNITE 6-1/2''...
I have a dual XIA3145 580 watt amp that keeps blowing fuses
Generally, this indicates that there's at least one shorted output transistor.
Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still blows the fuses, the amp almost certainly has shorted output transistors and will need to be repaired.
I'd recommend using two 10 amp fuses. The amp will power up with 10 amp fuses if there is no problem. If there is a problem, there's less of a chance of doing more damage by using the 10 amp fuses.
Let me know if you have any other questions.
babin_perry@yahoo.com
Sep 04, 2009 | Dual Electronics illumiNITE XIA3145 Car...
Blue illumination doesnt work
unscrew the plexiglass and try to get to the light and mess with it to see if it shook something loose, if that doesnt work, you might have to buy a new light....hope this helps!!
Mar 21, 2009 | JC Whitney - Dual Illuminite 12" Bandpass...
Started smking
Well, if it started smoking then it could be a few different things. First you need to clarify what was going on at the time it happend. Like, did you have it turned up loud? What are the ohms going to the amp from your speakers, you could have been running it below it's maximum rating for ohms. What kind of setup basicly are you running on it is what I'm asking then I could lead you to maybe the start of the problem or where to start looking. But it sound like you shorted out the power supply or the output transitors or both. Let me know what I asked then I can give more info. I have a degree in electronics and repair car amps everyday, it's what I do as well as collect them and sale them so I can help you. Clarify your request of what I asked then I'll reply.
Dec 29, 2008 | Dual Electronics illumiNITE XIA3145 Car...
How to install LED to car battery
power for what? what do u want to connect to battery?
Oct 26, 2007 | JC Whitney - Dual Blue Led Speakers Car...
Car Audio & Video Logo
159 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
