Question about Efficient Networks SpeedStream 5200 Modem
Connecting one network to another?
I have a PC on the first floor connected to a router on the second floor which is connected to a cable modem for internet access.
I will be installing a wireless (linksys) network on the first floor that needs to get to the internet modem and out on the second floor.
Using a wireless router connected to the PC on the first floor and using a different IP network, how do I get it to access the internet modem?
Thanks,
B.
    Sergeant:
  • 457 Answers
This is what I would do I would connect the wireless to the internet direct and allow all PC with wireless capabilities to access the net through that wireless irrespective to where I place the wireless router.  Alternative I would link the cable on on the second floor the one you use for the PC to access the net to access the the wireless it should automatic allocate IP addresses as each machine accesses the network.  The speed of that wirless is decreased as each wireless PC comes on line.
Posted on Oct 26, 2007
SOURCE:
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
How do you connect 2 routers into one network? I have a Linksys E3000 and a WRT110...I've had the wrt110 for over a year but I found I needed a second router to cover my entire house so I purchased a...
The easiest way is to run a long Ethernet cable from one of the 'LAN' (or 'network') ports on the "first" router to the 'WAN' (or 'Internet') port on the second router. The "first" router is the one connected to your cable-modem or DSL-modem. Both routers will auto-configure themselves for this "wired" connection. Configure the wireless-adapter in the second router as per normal.
Or, run a long Ethernet cable from the cable-modem (or DSL-modem) to a location in the "center" of your home, where you can put your wireless-router, such that its signal spans the entire building.
Or, move the cable-modem (or DSL-modem) to a location in the "center" of your home, and connect the one router at that location.
Dec 15, 2010 | Linksys E3000 Wireless Router
I have a belkin router i am having trouble connecting it. i dont know where to connect the ethernet cable. Does it go the computer or the modem?
the ethernet cable should be connected to the ethernet port of the router to the ethernet/network port of the computer. you will also need to connect a cable through the router and the modem, then a phone cable from the modem to the phone line.
Aug 31, 2010 | Computers & Internet
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
How to solve the lan problem
With only Cat 5 UTP cable segments, the maximum length for any cable segment is 100 meters, make sure that you don't exceed this. Also crossover cables are for switch to switch connections. You must use a straight thru cable from PC to switch port
Jun 01, 2009 | Computers & Internet
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
Nov 08, 2008 | Computers & Internet
PPPoE over Edimax BR-6104K without a modem
I am not sure if I understand you well.
You say:
My Internet is a PPPoE broadband connection but I don't have a modem installed.
What do you mean ?
You have a Broadband/ADSL modem, but you didn't install any software for it ?
(It is probably not necessary.)
So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres: 192.168.2.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
Open your browser and type http://192.168.2.1
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
PPPoE.
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APLY, and again APLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable. (***)
Now:
if you've typed your User Name and Password correctly in PPPoE fields,
and
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the PC with two NICs.
Go to Control Pannel, and go to Network Connections.
Right-click on one of your NICs and click 'Disable'.
Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
Connect the (enabled) NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
That's it!
Regards
Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Efficient Networks SpeedStream 5200 Modem Logo
218 people viewed this question
Top Efficient Networks Computers & Internet Experts
pongta rajkumar
pongta rajkumar
k24674
Tom Chichester
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
