Question about JC Whitney - Dual Blue Led Speakers Car Speaker
How to install LED to car battery
I just got a set of Dual Illuminite SBX554 speakers.
How do I connect the power to my car battery?
  • Anonymous Feb 06, 2008
    I just bought a pair of illuminite TS series car audio speakers and i need to install them into the back of a 92 toyota corolla.  the speakers need to be connected to a 12 volt DC source. How do can i connect to a 12 volt DC source the easiest?
For your amp.--- run a power wire from the +(red side of your battery) to the port labled +. then from the - on the amp run it to anywhere that ends up touching the major metal on the car, i used the baby seat hook.
For the cd player, same idea, + to battery and - to any - wire on yoru car or to metal. you didnt give us much to work with sorry...
Posted on Jun 19, 2009
    New Friend:
  • 101 Answers
Power for what? what do u want to connect to battery?
Posted on Jan 29, 2008
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 11, 2008
    WIRE IT TO THE FUSE BOX. OR RUN WIRE WITH FUSE BY BATTERY FOR YOU 12VOLT+ AND ATTACH THE GROUND ANY WHERE NEAR THE SPEAKER CAN WIRE IT TO THE MOUNTING BOLTS OF SPEAKER IF YOU WANT FOR THE GROUND{-}
    CHANGE THAT RATING UYOU GAVE ME PLEASE
  • chris ZAMBROTTA
    chris ZAMBROTTA Jun 03, 2009
    your a DI-K!!!!!!!!!!!!!!!!!!!
I have the same set, this may not help you much, but may be it'll spark some more ideas. My friend showed me a 12v source on the back of my sony xplod cd player that was only on when the cd player was on. Not sure which one it was, might have been for that att.(attenuate) function it has.
Posted on Feb 23, 2008
I hope this helps.... what my brother an i did was bought an adapter that hooks up to your cigarette lighter. This adapter plugs into the cigarette lighter, and you connect the positive and negative wires to it. You simply connect the wires, then run them to the trunk, and hook them up to one side of the speakers. Or you could cut the brake's power line, and then double wire it, then just take the power from there. hope this helps
Posted on Apr 28, 2008
2 Suggested Answers
BEERbrooklyn
  • 101 Answers
SOURCE: Dual SBX554
POWR TO BATTERY FOR WHAT?DOES THE SPEAKERS HAVE AN AMPLIFIER? NEW RADIO? SPEAKERS ALONE ARE NOT CONNECTED TO BATTERY ,UNLESS THEY ARE POWERED SPEAKERS,USALLY SUB-WOOFERS HAVE THEIR OWN AMP.iF YOU ARE CONNECTING A AMPLIFIER START WITH A FUSE SAME SIZE AS THE AMP,CONECT 1ST TO THE BATTERYTHE TO THE FUSE RUN A SIFICIANT GAUGE POWER CABLE TO THE AMP.GET THE GOUND FROM A PART OF THE CHASSIS CLOSE TO THE AMP,ALSO SAME SIZE OR LAGER GAUGE WIRE.THEN YOU HAVE TO RUN A REMOTE SWICH WIRE FROM THE BACK OF THE RADIO TO THE AMP.iF RADIO DONT HAVE REMOTE ,CUT INTO THE POWER ANTENNA WIRE .RUIN YOU RCA CABLES TO THE AMP AND WIRE YOU R SPEAKERSMbUT FIRST DISCONNECT YOUR GROUND FROM THE BATERY MOST IMPORTANT.ANY '?'S.WRITE BACK RATING PLEAse.
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
I have the dual xdv8125 car stereo and i hook all the wires up but nothn comes on. its hooked upto a 12volt dc power converter box. it wont do nothing at all.
Make sure that the DC has more than 3/5Amps rating with good DC to make the set working. Test with a car battery to confirm your connection if not check the speaker connections, the main power, switched power and ground must be in order.
Aug 28, 2010 | Dual XDV8125
I need a wiring diagram to hook up a set of dual illuminite speakers in my car
Check out www.The12volt.com
They have all kinds of wiring diagrams. Be careful.... Car systems are designed to handle certain number of speakers and resistance (ohms). Hooking up more speakers without the proper amplifiers can damage your cars radio.
Sep 20, 2009 | Dual XNP653 3-Way illumiNITE Speakers Car...
How to connect the 12 volt DC to the illumination lights from the tweeter
1) light have 2 wire R./B.
take R n connet with other B .n 2 wire r there two join too dc okk/............
Sep 07, 2009 | Dual XNP653 3-Way illumiNITE 6-1/2''...
I have a dual XIA3145 580 watt amp that keeps blowing fuses
Generally, this indicates that there's at least one shorted output transistor.
Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still blows the fuses, the amp almost certainly has shorted output transistors and will need to be repaired.
I'd recommend using two 10 amp fuses. The amp will power up with 10 amp fuses if there is no problem. If there is a problem, there's less of a chance of doing more damage by using the 10 amp fuses.
Let me know if you have any other questions.
babin_perry@yahoo.com
Sep 04, 2009 | Dual Electronics illumiNITE XIA3145 Car...
Blue illumination doesnt work
unscrew the plexiglass and try to get to the light and mess with it to see if it shook something loose, if that doesnt work, you might have to buy a new light....hope this helps!!
Mar 21, 2009 | JC Whitney - Dual Illuminite 12" Bandpass...
New Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Jan 27, 2009 | Dual (DBXPA6100) Car Audio Amplifier
Dual SBX554
Oct 26, 2007 | JC Whitney - Dual Blue Led Speakers Car...
Car Audio & Video Logo
2,645 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
