Question about ViewSonic VA1912wb 19" LCD Monitor
Display appearing stretched
The display appears stretched sideways on the wide screen
  • 3 more comments
  • McGuy Mar 21, 2008
    I had the same problem when opening Firefox browser and everything I opened.. any webpage, my gmail account everything, including the desktop, looked as if it was a shadow to the left, the shadow being the same color as the icon, font or image. But just now when I opened Firefox again it didn't look as bad, but my desktop still looks that way.
    Monitor is only one (1) year old.
    What could it be?
    Thanks a million!
  • Anonymous Jul 14, 2008
    fron strech in 19 inch lcd
  • pia1126 Dec 05, 2008
    my acer gor reformatted and when i opened it the display was stretched and it was so weird. even my microsoft word is stretched everytime i make a report. how do i fix this? i want the old one.
  • Need_help09 Jan 10, 2009
    I have the same problem. I tried to change the setting however the menu won't let me access the 'Aspect Control" and i'm not sure why.
  • imageswmv Jan 24, 2009
    I have the same problem with the aspect ratio option being grayed out - everything gets stretched in auto adjust and is so ugly, any ideas?
The original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Posted on Jan 10, 2008
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
My screen is turned sideways
Go to control panel select display, change display settings, then go to the drop down by orientation and select landscape or portrait depending on whether you have your screen turned tall or wide. If tall select portrait, if wide then select landscape.
Jan 07, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Why is image on screen is to wide
A wide screen display requires setting the appearance
procedures
1. right click on a space on the desktop without icons
2. select from a list prompt the settings with click should provide link with which to select the appearance setting
3. choose from the display icon prompt after clicking a pixel quality
4. a larger figure chosen from the list should decompress the screen pixels creating clear pictures though adjusted screen to fit the area
Dec 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Image stretched widthways
Hi
Depending upon your operating system: Right click on an open area of the background screen. The goto to settings or display settings. From here you're going to want to change the display resolution or display size to match your monitor. Experiment with the different sizes until you get the one that's right for you.
May 13, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
Laptop display problems
Hi Neela
Thank you for your query
Please try the following
1) Right Click in the middle of the desktop
2) Click on Properties
3) In the display settings box that appears click on the tab that says settings
4) The settings can be adjusted from here i..e screen resolution and colour quality, the display adapter can also be checked to ensure it is correct i.e. yours should be something like nvidia etc etc
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 24, 2010 | Dell Inspiron 1420 Laptop
I can't get my screen to view properly. It's a wide screen, and it's stretching my images to fit the screen. It used to display properly, but somehow it got shifted to this new "stretched" view....
  • Move to the control panel.
  • Click the display button.
  • Then choose the right order of the screen, visual display.
  • If then also u counter a problem then u need 2 move 2 d screen, thn right click.
  • After this go to the display tab and check ur visualization & your color bit tabs.
May 21, 2008 | Toshiba Computers & Internet
ViewSonic VA1912wb 19" LCD Monitor Logo
1,176 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
