Question about ASUS P5RD1-VM Motherboard
Computer wont start up when i add another 512mbs of ram
Yea BOTH sticks of 512 ram work because i used both on there own each but when i put both of them in at the same time the computer starts but no screen.....
I just had this exact problem with the same ram and mobo, downgrade your mobo firmware to the 2nd newest, worked like a charm
Posted on Oct 29, 2007
  • 661 Answers
It is possible that there is some Memory incompatibility here (as I have seen this before). slightly incompatible RAM will work on its own, however when the second stick is added the system won't start.
I find that KINGSTON provides reliable mem and they have a web tool with which you can search for the device that you have.
(where they have tested and confirmed that the specified memory works), I think this is great and have used it several times myself.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25866&mfr=ASUS%2FASmobile&model=P5RD1&root=&LinkBack=&Sys=25866-ASUS%2FASmobile-P5RD1-VM+Motherboard&distributor=0&submit1=Search
Posted on Oct 26, 2007
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
I have a Acer Veriton M410 and if I try and add additional memory the PC will not boot, just beeps. I tried every combination of ram with the same negative results. The system came with two sticks of 512...
That motherboard will use any of these 3 memory sticks.IN PAIRS.if you just put in 2 make sure the go in the same colored slots.
DDR2 PC2-4200
DDR2 PC2-5300
DDR2 PC2-6400
Each slot will take upto a 2gig memory stick.For a max of 8gig.
Use matching pairs.
May 22, 2017 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
I have a Dell GX620 that I rescycled.It wouldn't power up so I put in a different power source and put in 1 - 512 stick of memory. It then started up and I reformatted the hard drive and re-installed...
just leave in one of the new 1gb stick of memory
if stable memory was the issue so add the back one at a time each time shut down install turn on test
if still unstable coould be the hard drive
May 29, 2011 | Dell OptiPlex GX620 PC Desktop
Which ram goes where?
Hi, There is no particular order from which you would put your RAM sticks into those slots. however, if the Slots are color coded (2 reds, 2 whites for example), you should put the same sticks in the same color. so make sure those 512mb sticks are both in red and your 1 gb sticks are both in white (colors were just set for example, actual ram slot color may vary). Those color coding were done to use the dual channel pairing of RAM sticks so the same type and speed of RAM sticks should be placed on same colored slots.
Jun 15, 2010 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
I have a dell b110 dimension...i took the memory out to see what kind of ram it was to add more to the system. When i replaced the ram, it wont boot up. when you push the power button, it hums like it is...
Check first if the memory is loose or there are any parts that have come loose such us IDE or SATA cables, For errors you should also get warning sounds.
Sep 07, 2009 | Dell Dimension™ B110 PC Desktop
I have a Gateway laptop computer with XP. It originally had 512mbs of memory. I bought 2gigs of memory and installed it. It worked lightening-fast for about one day. Here is what happened: My wife...
I was initially confused about the addition of the Dell laptop in the plot before realizing what you are saying:
I think its your RAM. Did you ground yourself while removing or replacing the ram to prevent static shock from damaging the device or memory sticks?
If not, try getting another 512 stick (pretty cheap) from best buy for your gateway and testing it out. Save the receipt.
Also, post the model of your gateway laptop as some computers can not handle large amounts of ram. Most will only allow up to 2x the original amount.
Dec 06, 2008 | Computers & Internet
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
OS won't work with RAM upgrade
Hi !
if u wanna upgrade RAM ,ur RAM should be of same capacity in both slot. i mean to say if u wanna use 1 GB....then put 512 & 512 or else put single 1 GB. But u cant use 512 in one slot & 1 GB in another slot at a time. if u do the combination like that ,it will never work.
--APARNA (Mumbai)
Jan 12, 2008 | Foxconn WinFast K7S741MG Motherboard for...
ASUS P5RD1-VM Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
