Question about Epson CX8400 All-In-One InkJet Printer
EPSON CX8400 DRIVEN PULLEY
4 Suggested Answers
SOURCE:
  • 11 Answers
SOURCE: Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Posted on Jul 07, 2009
iGorotECH
  • 7 Answers
SOURCE: My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Posted on Oct 20, 2009
podita
  • 324 Answers
SOURCE: how do I setpmy epson CX8400 printer?
hi please use this URL to resolve the issue, drivers, user guide included
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=vRaxNXeC8ziwyRAc36Fnlteew3ygivV1VHrAHpr+QeAU003D
your vote counts
Posted on Mar 25, 2010
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
How do I setpmy epson CX8400 printer?
your vote counts
Mar 25, 2010 | Epson CX8400 All-In-One InkJet Printer
I have a supermarket till receipt stuck in the works of my epson dx 8400 how can I get it out
***hi there,il be willing to help you on that. ****
If paper is stuck inside, turn off the Epson Stylus CX8400 Series.
Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX8400 Series back on.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson CX8400 All-In-One InkJet Printer
Epson cx8400 printer "setup" bbutton not responding
lost disc and want to download my epson to this computer
Jan 04, 2010 | Epson CX8400 All-In-One InkJet Printer
1. Press Setup
4. Press Start
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
I have been trying to scan with my epson cx8400 went to self help but cannot seem to get the scanner/printer to work
To scan: Insert doc. onto the scanner then go to Start menu, all programs, epson scan, epson scan
Oct 15, 2009 | Epson CX8400 All-In-One InkJet Printer
Cannot Print from on Epson CX8400 from Mac OS X Leopard
I could only get my CX8400 to work with Leopard once I manually selected the driver located at /Library/Printers/PPDs/Contents/Resources/EPSON Stylus CX8400.gz
I think that may have appeared after installing a driver downloaded off the web, but I didn't track my steps carefully enough to be certain. I used http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
I know this is a bit jumbled, but hopefully it helps.
Jul 08, 2009 | Epson CX8400 All-In-One InkJet Printer
Papers
Tape a piece of paper to the back of the transparency, works every time.
Aug 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson printer CX8400
Let me know if you find it--my computer and the printer show that my ink cartridges are full, but blank paper comes out when I try to print.
Jul 23, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
