Question about Panasonic Standard (CRT) Televisions
Panasonic 100hz tv
Our tv is only about 2 years old. When I turned it on this morning, the picture was purple and green, and looked similar to a negative. I have unplugged it and left it off for most of the day, but there is no change.
4 Suggested Answers
  • 29 Answers
SOURCE: Purple tint
Do not put a colour television near a strong magnetic field. I have confirmed from several experts that this has the undesired effect of causing loss of colour
Posted on Jan 11, 2006
  • 275 Answers
SOURCE: 3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Posted on Aug 22, 2006
  • 3130 Answers
SOURCE: Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Posted on Oct 08, 2006
  • 1591 Answers
SOURCE: mitsubishi ws-55807 wont stay on. the green light
There's a good chance you have failing electrolytic capacitors most likely in the power section.
Any caps in this or other sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably turn on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
As you can see, this issue spans plasma TVs, as well as large and small LCD and projection TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 27, 2011
Testimonial: "thank you very much for your help, browsing this site i tried a test suggested and i got the 2.2 blink code response from my t.v. what does that mean?"
0 characters
1 Points
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Screan turned a shade of purple
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
Nov 21, 2008 | RCA Standard (CRT) Televisions
Magnavox mptv68a
Last year i had a phillips 100hz tv which had a similar problem.
There can be one of 2 major problems :A processor chip which controls the colour and the tube which could have failed or both.
This could be an expensive repair if the spares are available,(Usually imported from there singapore branch)
I would first check the warranty and then take it to the agents.
Apr 28, 2008 | Philips Magnavox 27MS343S 27" TV
Lost picture
check for any DRY SOLDER in the pc board , if it still doing the same thing , then replace the VERTICAL OUTPUT IC , and please get the original replacement , generic part no guaranteed that will work 100%
Apr 17, 2008 | Panasonic CT-27SC13 27" TV
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
Screen turns purple
Loss of green = purple!....Please give model # and age from
back of set ........T.
Oct 27, 2007 | Standard (CRT) Televisions
Sony Trinitron 32 tv
1) Could be bad CRT ( picture tube )===no green==purple.
 2) Might be lack of green drive to CRT==bad transistor.
 Recommend analysis by technician--usually worth it if CRT ok.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
Aug 04, 2006 | Toshiba 36A40 36" TV
Standard (CRT) Televisions Logo
22 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
