Question about Eddie Bauer Lightweight Travel System 01-750-AFD
TAKING OFF THE CANOPY
I CANNOT TAKE THE CANOPY OFF MY STROLLER TO WASH IT. HOW DO I TAKE IT OFF?? I cannot take the canopy off my stroller to wash it. How do I take it off?
  • sherri69 Jan 05, 2008
    cannot get the canopy off the larger arched pole i took the 2 screw of the smaller arch but i cannot figure out how to get the other arch the front one disconnected to wash the canopy.
There are two tiny screws on each side of bar the the canopy is wrapped around. Unscrew them and you will able to slide it right off!
Posted on Oct 26, 2007
I have a safety1st stroller that i need to wash, but i can't take it all the way appart especially the canopy part
Goodmorning,
You could try very patiently with a screwdriver to remove the stroller cover (the chair part) as well, but you have to be very patient with the strap/belt. Then once it is completely removed, you could wash it at a very low temperature in the washing machine and dry it in the open air.
Good work!
Celeste
May 31, 2011 | Safety 1st 01929PAC Travel System Stroller
Washing stroller
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Sep 01, 2009 | Evenflo Aura Traditions Travel System...
Canopy broken on my fisher price stand and ride duo stroller
I have the same problem FisherPrice customer Service is useless. I would even buy a new canopy frame
Jun 01, 2009 | Fisher Price Baby Gear
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Maclaren double stroller canopy
I need a double canopy for a black twin traveller maclaren
Dec 03, 2008 | Maclaren Rally Twin - Navy Umbrella...
Frog canopy removal
Pull gently on the plastic arches that support the canopy (on either sides - where they connect to the stroller) and slide the canopy off.
Nov 05, 2008 | Bugaboo Frog Stroller
Cosco Eddie Bauer Stroller Canopy
the lower frame bar locks the canopy onto the frame. Remove this and remove the brackets from the frame. drill out the rivit on one side (take note of the location of the snap and washers) and then remove the frame from the bracket and canopy. you then use a 1 inch 5/32 rivit to reassemble.
Jun 22, 2008 | Cosco Eddie Bauer Lightweight - Blanchard...
Eddie Bauer Travel System - Removable Hood??
Took me awhile to figure this one out...
There are two bars attaching this hood to the stroller. The rop bar is obvious and removed by taking out 2 phillips head screwdrivers.
The bottom bar seems much more tricky as it seems "permanent".
Upon closer inspection, the lower metal "hood bar" goes into the side of a round clip. This round clip has a button snap in the middle of it. This round clip can be removed by pulling on it (not intuitive at all). It is not bolted on. It turns out it only encircles the metal bar it is attached to 3/4 of the way like a c-clip and will stretch to come off. You cannot remove the bar from inside the hood, but you can toss it all in the washer! Good luck!
May 24, 2008 | Eddie Bauer Lightweight Travel System...
Canopy
what I would do is try to find a way to completely detach it bars and all. they hand wash the whole thing...bars and all in the bath tub or something. This is what I did with my eddie bauer tandom stroller (worked like a charm)
Oct 28, 2007 | Eddie Bauer Lightweight Travel System...
Eddie Bauer Lightweight Travel System 01-750-AFD Logo
1,048 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
Douglas Dinnebeil
Douglas Dinnebeil
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
