Viewpia lcd hi got a client with a viewpia lcd model no lc-32it21 no pic pinky raster with white line???
  • 1 more comment
  • nivlekk Jan 26, 2009
    hi i have the same problem any ideas , i have been trying to find a viewpia hel pline
    thanks kell
  • Anonymous Mar 27, 2009
    HI Andy
    I have just experienced the exact same problem with my Viewpia.
    Have you managed to fix it?
    WOZ
  • andrew72 May 19, 2009
    Exactly the same prob. on 15/05/2009. While retuning to pick up new channels, screen goes blank and tells me "no signal" . Has anybody had any luck yet? Viewpia helpline or anything????
    Andy Mac
Click menu, on station prog go to EDIT. Press blue button twice, then go to rescan prog. (it seems to clear all previous scanned programs and starts again.
Posted on May 20, 2009
  • andrew72 Feb 01, 2010
    The Viewpia has not got the 8k mode inside the T.V. It cannot be retuned. Have now got a full refund from supplier. I had to quote the fact about the digital tick logo and what it meant and the set being advertised as HD ready. This is not the case. and as such under office of fair trading etc. the set was originally sold "unfit for purpose" Good luck all in your claims.
    p.s. Viewpia no longer in U.K. and no back up either..Gone to holland and not helpful!!!!!!!!!!
I've had the viewpia for 10months with no problems until i decided to rescan for new freeview channels. Now all that appears on the screen is a notice saying no signal,after checking all cables which were fine, i retunned the TV to terrestrial channels which all worked fine.
Any ideas,
Andy
Posted on Nov 15, 2008
Hi
I had the 'No signal' problem and successfully resolved it.
Menu
Edit tv
Delete all programmes (blue button did complete list)
Rescan
Good luck
Julian
Posted on Jan 29, 2010
Ihave pinky white lines down left side of tv about 2 inch wide and 8 inch long
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 02, 2015 | Televison & Video
I have sound but no picture on my tv sharp aquos 20 inch
if you mean have sound but no Pic.or no raster, horizontal section is the culprit. most problem is at the Horizontal output section that drives the Flyback transformer. Pull out that HV cap & test them to ground if there is some arc coming out. No arc means failed output section or the flyback transformer need to be replace..
Sep 25, 2013 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Can i hook up my xbox 360 to my aquos tv with just the red, yellow, and white cable? Right now I am not getting a color pic
Yes you can but it won't be Hi def. It sounds like you're trying to connect the cables to the Hi def input (Red, blue, green, white and red for the audio) That's not the right place to connect to.
Dec 28, 2010 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
When taking pics they end up pinky/purple with horizontal lines
Hi!
It's a loose connection between the CCD and motherboard - a very common problem with these cameras. Unless you have experience in camera repairs, you should give it to a local repair shop - don't let them say you it's a motherboard problem or something like that, it's 99% just a loose connection. I have repaired hundreds of these. I work in a Kodak service center.
Tom
Aug 30, 2009 | Kodak Easyshare M753 Digital Camera
LC-45GX6U
The DC/DC converter went out on your set. When you take the top off of your AVC box look for a 4" X 5" circuit board mounted on the front left corner. I have seen these fail causing you white screen. Order the part from your local Sharp service center. Part # RDENCA089WJZZ
Jun 16, 2009 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Orange Led syndrom
I found the following solution on internet:
VIEWPIA LCD
Make: Viewpia
Model: LC-32IEB2
Fault: Unit held down with only orange LED lit
Remedy: Remove the main metal screen cover from main board and check the input
voltage on to the main 3.3Volt regulator IC202 it should be bang on more or less
5Volts, if not replace capacitors C905 330uf 10v C908 470uf 10v both are to be
found in the main power supply section.
J Williams
www.jvsvisual.com
Unfortunately I'm not very technical so now I will need to find someone to do this for me...
Dec 22, 2008 | Televison & Video
Dell Ultrasharp 2005fpw
The problem you are describing is definitely a bad picture tube.please replace it or the problem you are describing sounds like high voltage regulation problems. The easiest way to tell is by changing from a black raster to a white raster. If the size changes quite noticeably or jumps alot then you have a regulation problem. The first thing to do is check your high voltage while changing the raster from black to white. If the HV varies by a large margin, then you have a flyback problem. If it doesn't, check the voltage at the collector of the HOT while varying the raster again. If the voltage changes alot then check your B+ line. Typically what goes out in this case is a capacitor(typically 100uf-350v or so) or the B+ regulator. Hope this helps.
Jan 26, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Sharp lc 20sh1e lcd tv funny picture
Do you still have this, I need a part myself and having trouble sourcing parts?
Mine immediately goes into standby mode and the screen just shows a white flash. I'm sure its just a power issue.
notallbad1@yahoo.co.uk
Nov 27, 2007 | Sharp Aqous LC-26D5U Television
Televison & Video Logo
1,357 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
