Question about Lexmark X1150 All-In-One InkJet Printer
Printhead When I turn the printer on the printhead slams back and forth instead of moving smoothly like it normally does. When trying to print I get the error: Cartridge Stall There is nothing blocking the printhead and cartridges is firmly in place.
I suggest smoking 2 doobs and just kicking back and relax'm lidat. If not then go wit da ganjas.
Posted on Apr 15, 2008
    Genius:
  • 1,601 Answers
"Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 Printhead - null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Posted on Nov 16, 2007
Printer jams, printhead gets stuck and won't slide back or forth
try getting some machine oil and put a small amount on a tissue and rub onto guide bar .
Mar 28, 2016 | Epson DFX 8000 Matrix Printer
Printer problem
YOUR CADRIGE IS NOT COMPATIABLE WITH YOUR PRINTER
Jan 21, 2008 | Computers & Internet
Why is printhead suddenly slamming to the left?
Just drip a few drop of oil on the carriage rod. This might solve the problem.
May 03, 2014 | Kodak ESP Office 2150 All-in-one Printer
Alarm message says "cartridge jammed". Does that
What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
blocking the path of the ink.
Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
If the alarm message continues, I suggest changing the ink cartridges.
Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
Have ink, but its not printing. the paper is doing the right thing ,but not putting ink on paper
Please make sure that the print head is not clogged. The ink can flow out easily from the print head. How do you know if there is no dry ink clogging the print head? Remove the cartridge and run the print head in a soft smooth paper, see if the inks was left in the paper proportionally. If no ink marks then its clogged.
flushing the print head of the cartridge directly from the tap water will help ....Open your printer cover, remove the cartridge..place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead. Turn the print head over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm).. tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
The last thing to do and it will take you sometime is to soak the printhead portion of your cartridge in a mixture of ammonia and hot distilled water, (please make sure that the contact point of the cartridge to the printer is not soak).. Place the printhead on the hot water and leave it there for about 4 to 5 hours..move it on different location from time to time..After soaking, rinse it with distilled water and dry it with cloth...
After doing the instructions, return back the cartridge to the printer and do the printhead alignment..
Try printing a test page and see the outcome...
If you find this information very helpful, would you be kind to rate this solution. Thanks
Aug 18, 2010 | Brother MFC 420CN All-In-One InkJet...
After changing the print head and setting the Ohm resistance, the left side of the printed labels are faded. I adjusted both head pressure and slid them back and forth but I can't get it to print right....
It's very possible the printhead wasn't installed correctly. It's pretty easy to get it wrong, as there are two pins on the latched printhead bracket that have to fit into two holes on the printhead itself. You have to get the alignment of these pins and holes just perfect before you tighten the screw. You have to make sure the aluminum plate on the printhead is sitting flat against the printer's printhead bracket before you turn the screw on top of the bracket.
Sep 24, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Ink heads
Removing the printheads from Epson printers is not recommended as you can successfully clean them while they are still installed and with less chance of borking the printer by forgetting where that screw went :)
To do this you need to turn the printer on, let the printhead move off the parking pads (where the printhead rests) and then immediately pull the power cord so the printer stops.
This will allow you to freely move the printhead to the far left out of the way.
You now need some ammoniated windex or a similar cleaning solution (try asking your ink supplier) compatible with inkjet printers.
Using a kitchen paper towel, carefully fold it four times and then soak this in the solution before putting the paper pad so it sits over the parking pad. Now move the printhead so it sits over the solution soaked pad and leave for 12 hours (don't turn the printer on or plug it back in).
Remove the original pad and put in a new one and leave for a further 12 hours.
Note: This approach allows the cleaning solution to wick up into the printhead nozzles and break down the clogs, returning them to solution and allowing you to clear them out. It requires time to let the solution do its work which is why it's critical you don't try to rush things..
Now, remove the pad, plug the printer back in and turn the printer on... Wait for the printer to stop it's initial routine and then run a cleaning routine and a nozzle check...
Leave the printer for a further hour just to let things settle some more and then print a new nozzle check...
You should find that that the printhead will have cleared out a great deal of clogging.
If your printhead has been clogged for some months you might want to change the pads more than once and extend the period over 2 to 3 days.
Whatever you do, don't try brushing the printhead back and forth over the soaked pad and avoid more than one cleaning cycle in a 3 hour period.
Hope that helps.
Mar 09, 2009 | Epson Stylus R380 InkJet Photo Printer
When I hit print, my z22 makes a grinding noise.
It sounds like the belt that moves the printhead is worn out or, the print carriage is stuck. With the ppower turned off, lift the lid and gently try to move the printhead back & forth. If it doesn't get stuck, the belt's bad. If this is the problem, replace the printer. It's close to the same price as replacing parts.
Feb 14, 2009 | Lexmark JetPrinter Z22 Color InkJet
Head cleaning after cartridge change
It sounds like you're trying to force the printer to clean the printhead and only ever partially resolving it before it clogs up again.
Ok... first you need to do is get a decent cleaning solution that can help de-clog the printhead. Usually Windex (the ammoniated version) is a good option but you might want to get some from your ink supplier.
Cleaning cartridges may be worth considerinb BUT I only ever use these are a passive cleaning system, not as active "clean NOW! dagnabit" impatient approaches.
Right, anyway... process is this.
  1. Leave your existing cartridges in
  2. Find a piece of paper kitchen towel or if possible a lint free piece of cloth and soak it in the cleaning solution. Fold into a 2mm or so thick pad.
  3. Move the printhead off the parking pad and out of the way to the left. (usually by starting the printer, waiting for the head to move and then pulling the power cord so you can freely move the printhead).
  4. Place the pad of solution soaked kitchen towel and then move the printhead back to sit over this in the parking pad.
  5. Then go make a cup of tea/coffee, do the ironing, or whatever but leave it alone for at least overnight.
  6. Remove the kitchen towel pad and replace with a fresh one
  7. Leave for a further 12 hours
  8. Remove the pad and turn the printer back on
  9. Run a SINGLE cleaning cycle and then a nozzle check
  10. Let the printer sit for an hour
  11. Try using the printer as normal.
What this approach does is allows the cleaning solution to slowly break down the clog by whicking up into the printhead nozzles and over time turn the hard pigment into a solution again. This requires time so patience is an absolutely essential ingredient.
A few things to note...
  • Obviously don't try to force a thick wad of paper towel under the printhead.. a single fold should be enough
  • DO NOT use the towel to scrape back and forth across the printhead as this will damage the printhead (it is incredibly sensitive and paper towel is more abrasive than you may realise!)
  • The cleaning solution is not just some off the shelf oven cleaner... If in doubt use distilled water and add more time to the process
  • If you're using cleaning cartridges do not use them to force clogs out... Instead allow the solution in them to work on the clog from above in the same way as the pad of solution in the parking pad will work on the clog from below.
Hope this works for you and try to adopt more pro-active measures to reduce the likelihood of clogging ie:
  • move out of particularly hot/warm rooms
  • move away from radiators
  • use the printer regularly (don't leave it idle)
The last one is the kicker... It's a lot like having a dog... They're happier if they're kept exercised so don't save the printer for special photos or whatever, try to use it for the odd graphic, letter too.
Good luck :)
Jan 17, 2009 | Epson Stylus Photo R1800 InkJet Printer
Dfx 8000 not printing
Check the printhead guide bar for proper lubrication- light oil similiar to 3 in 1 will work. Check for any printhead cabling catching on something as the printhead moves back and forth. If error beeps are occuring immediately after turn on, and unit will not print, this might indicate a sensor problem, such as paper sensor, head home position sensor or another error condition of some sort.
Apr 07, 2007 | Epson DFX-8000 Matrix Printer
Lexmark X1150 All-In-One InkJet Printer Logo
415 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
