Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
Sylvania 6842pem My tv seems to have the same trouble as others. Just made a loud pop, now it won't turn on at all. It is over a year old, so parts warranty is not possible.Can a regular person, me for instance or my computer wizard brother maybe, repair this capacitor problem? It is referenced several times that the ceramic capacitor is most likely the problem, and if must be replaced with a "special type of capacitor". What type, and where can I get one? Much ThanksSandi
  • 1 more comment
  • Anonymous Jan 21, 2008
    I posted the same problem several months back. I took the TV to a local repair shop and they discovered that the monitor panel was blown. The repair center contacted Syvania and after about a month found out that the part was not available. Sylvania agreed to refund the purchase price. It took a couple of months but I got my money back. Bought an LG - not plasma this time. :)
  • stevenplane May 11, 2010
    Would love to email Zexall but not sure how. Actually, since this morning I've identified/removed the bad capacitor and replaced it with a new one (from Radio Shack). The old capacitor was obviously blown as Zexall indicated. Had no trouble soldering the new one on...all appeared perfect but one problem. It didn't work. The television still doesn't stay on. There's a flashing green light on the power supply below and slightly to the left of the bad capacitor. There are no other obviously "blown items." I might just try replacing the entire supply next. Unless I can get some other pointers from Zexall...perhaps you know how to reach him?
    Same problem with recently purchased sylvania. Where exactly is this capacitor located? Upper left side? I can't find anything that looks "burned out". Also, how do you safely remove power supply without getting a jolt? Any digital photos maybe?
    Thanks,
    Steve
Hi steveplane,
Sorry, I don't know how you could get to him either. Maybe he will get a notification on this......I dunno, sorry. Good Luck, I hope you get it to work.
Sandi
Posted on Jan 20, 2008
To steveplane. You had emailed me for additonal info. Sorry, but I never got mine up and running. I was unsuccessful at identifying the capacitor in question, and was unable to purchase one at any electronics store, including Radio Shack. Sorry I couldn't be of help. I suggest for you to refoward or repose your questions to Zexxal?
    Problem Solver:
  • 11 Answers
Yes, you can get a 50 watt capacitor from Radio Shack and put it in yourself. It cost me $ 1.45 for a package of 2. Just ask them for a 50 watt capacitor
Just be careful when you remove the board, it holds a charge for a little while. I know from experience 8-)
Just take a small soldering pencil and remove the old one, then add the new one. You can get everything you need from Radio Shack for under $20 bucks. (if you have nothing to work with (solder, iron, capacitors Etc)
One hint, be careful with removing and adding the new one, don't burn or scrap the board and make sure when you add the new one not to put to much solder on the connections. Before you put the board back in, verify that you did not leave any solder on the board or cross the connections with the solder.
Believe me, this unit is very easy to work on and you should not have any issues.
Good luck. Hope this works for you.
Let me know if you need any additional information.
Posted on Nov 14, 2007
Sylvania SRT2232S 32" was working
The problem is in the vertical deflection circuits which is responsible for giving a full picture. Since the set is 8 years old the money would be better spent on a new tv since more frequent break downs in other parts of the set would be more likely due to age.
Sep 15, 2011 | Sylvania SRT2232S 32" TV
Tv turns on and then right back off
it sounds like one of the boards are going out I would call sylvania and check with there service dept maybe they can send a tech and part out under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
SYLVANIA 42 INCH 6842PEM DOES NOT TURN ON
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Hi I have a sylvania 6842pem 42 inch plasma. when turning the television on it makes a weird screeching noise then goes to stand by. what can the problem be thanks for the help
your transformer on your power supply is bad, i would recomend replacing the power supply, usually when the transformer goes bad , it damages other things on the board, should be around a 200$ part
Jan 11, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania Power Board
I had the same issue. Turned out to be a blown capacitor on the power board.
<a href="http://s133.photobucket.com/albums/q68/rwlib3/?action=view&current=DSC_0426.jpg" target="_blank">
Jun 15, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Standby mode
It happened to me.. a FAx to Enrique. in California.
May 01, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania 6842PEM
Have fixed a bunch of those as a Sylvania ASC. There is a small ceramic capacitor on the main power PCB that has ruptured. It must be replaced with a different part, a special type of capacitor, or it will just fail again. Sylvania had recommended replacing the main power PCB rather than repair because sometimes there was additional damage on the board, however replacing the capacitor fixed every one that came to us. I preferred that because some electrical voltages have to be adjusted if the circuit board is replaced with a different one.
Mar 28, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
133 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
