Question about Samsung HCL4715W 47" Rear Projection Television
Color misalignment colors don't line up. what can be done to correct this?
  • 1 more comment
  • ccoindreau Nov 03, 2007
    I have the same problem and I think we need the original remote control. I've tried with ani universal and doesn't work. Do you have the original remote?
  • ericvaug Nov 17, 2007
    samsung 47 inch red color is not aligned tried focus no help the red is a double image about 1 inch out of alignment
  • TaraB Nov 28, 2007
    I have the same problem, and I have the remote. I have tried Perfect Focus, no help. I've tried the mute-1-8-3 function - the grid lines line up on the first 3 inches of the screen and then don't after that. I'm not really sure what to do when I get to that screen. Is this something I should be able to fix myself, if so, how do I do it? Or should I call a repair person? Thanks.
  • 375 Answers
Contact sears for a replacement remote.
Posted on Nov 15, 2007
My printer (mp 160 pixma) shows error code 5,3,2 what is the problem
E2 = Reload the paper correctly and press [Black] or [Color]
E3 = If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [Black] or [Color].
E5 = The FINE Cartridge may not be installed properly, or the Cartridge may notbe the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Nov 02, 2013 | Canon Pixma Mp160 Mp 160 Photo All-in-one...
How To Deal With Color And Line Misalignment
Have you ever experienced this problem with your inkjet printer?. The printing result of document or picture get little bit shadowed, some colors and lines are misalignment.
Take it easy. It's not a big deal dude!. The problem frequently happens when we remove the print head or cartridge from carriage unit. And then, the print head is not always in proper position after we reinstall it.
on Sep 19, 2012 | Office Equipment & Supplies
Canon ip2770 alignment
Hope it helps.Thanks!
Oct 02, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Hi folks! I have a Viewsonic PJ400 projector. He
Which "lenses" did you clean inside the unit. It would seem that you have misalignment of the lcd panels or the phase setting may need adjusting. What input are you using and what vertical frequency is the signal using?
Jun 30, 2011 | Office Equipment & Supplies
I have a lexmark c912. One day I noticed the colors weren't lining up properly. Shortly after that, there appeared a color distortion in the lower right corner. It was as if the magneta wasn't...
The proper color alignment is in the Config settings. This should only be done a certified tech. Can really screw things up bad if you don't know what you're doing. I am a Lexmark Tech.
Mar 02, 2017 | Lexmark C912 Led Printer
Red, yellow and blue bars going through the screen, what does this mean and how do I correct it?
U mean ur tv have colors shadows?Colors lines Red,Green,Blue misaligns don't line up to produced a solid picture?U have a 3D pic?All these are cause by a problems known as CONVERGENCE PROBLEMS.Ur tv the convergence board the 2 convergence ICS and some or all it resistors are dead.All these parts on the convergencce board,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 15, 2010 | Toshiba TP50H50 50" Rear Projection...
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Samsung HCL4715W 47" Rear Projection Television Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
