My Kodak 760h Carousel came with autofocus, which no longer functions correctly. I have been able to verify that the small white plastic worm gear on the worm shaft is cracked, which allows the gear to slip on the shaft rather than move the lens. I have found a place that sells a replacement worm shaft gear assembly, but cannot figure out how to disassemble this projector in order to replace the parts.
Check with the dealer who is selling you the part, to see if they can provide you with the required pages for disassembly, repair & re-assembly from the Kodak Service Manual. You should be aware that in some cases when this repair is made, it requires the technician to re-calibrate the auto-focus system. To do that, you will need 2 special tools (a "Target Slide" and a "Range Slide"), that were manufactured by Kodak for use on the assembly line and by their authorized warranty repair dealers. You MAY need those, as well.
As you can imagine, all this can begin to get expensive (if you can still get the special tools).... It may be more economical to try to locate another used projector on the internet... Here are 2 dealers I can recommend: For parts & tools - www.micro-tools.com
For used projectors - www.vinevalleyimaging.com
Good Luck!! Jim
SOURCE: My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
SOURCE: Kodak Projector 760H. Carousel won't
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
SOURCE: Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
SOURCE: I am unable to latch the slide tray into my 760H
Terry,
I think I already answered this one, but it still appears in my question cue.
Make sure the locking ring (on the top of the tray) is on TIGHT on the slide tray. Turn the tray upside down. Rotate the metal plate until the arrow stamped into it lines up with the notch on the bottom of the plastic tray. That should solve your problem. Jim
