Question about Gateway FPD2275W LCD Monitor
Boka monitor problem
Have a horizontal white line on the screen
can you show me the picture of the damage vertical
  • cornelio Oct 27, 2007
    thanks i will try!!!
    thank you very much! i will try .
    Brigadier General:
  • 6,966 Answers
Below are images of the vertical IC of a Boka MO-15NF. The first shows its general location which is almost at the center of the board.  The second is a close-up.  Hope this be of help. Good luck and kind regards.
Posted on Oct 26, 2007
  • Louie  Role
    Louie Role Oct 27, 2007
    No prob, would appreciate if you would then rate this response accordingly.
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Monitor is only showing vertical/horizontal gray/white screen
Your video card has fried unfortunately. If you are familiar with the internal workings of a PC you can open it up and check the power cells on the video card itself, they will usually show signs of damage such as cracking etc. I would have a qualified professional take a look at it. I would recommend as a starting place for finding a new one
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Vertical Wavy lines moving upward in my monitor
i think you have a faulty Fly Back Transformer { FBT / EHT }.
Mar 09, 2008 | Gateway FPD2275W LCD Monitor
Boka monitor is black out
try to check the horizontal output
Nov 10, 2007 | Boka 206 Computer Speakers
Monitor Problem
after u open the monitor at the back of the cord which have a heat sink that the ic vertical # lm2469ta
Nov 05, 2007 | Compaq CV 7500 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
297 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
