Check the following to address this issue.
Note: Normal drying time for a dryer
is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct,
is not clogged.
Unless regular maintenance is performed, chances are there is a lot
of lint accumulated inside the dryer. This might affect the drying
time and could be a fire hazard. Make sure to have your dryer
cleaned regularly. Because this might involve taking most of the
dryer apart, it is recommended to have a qualified appliance
repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one
of them breaks down, it might affect the dryer's performance.
Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case
it would still work but will take longer time to dry the clothes.
Replace the element if found defective.
