Question about HP Photosmart 3310 Printer
Memory Card Error
I have a  HP model 3310 photosmart all in one printer and this error message has come up on the screen and I cant get the printer to reset
  • blmaltz Nov 13, 2007
    I have a memory card error. Have tried to reset by unplugging and pluging back in while pressing the 6 and # keys. still no reset.
    Master:
  • 474 Answers
If you can do so, go through the menu options and look for the ' restore to factory defaults option and do it.
Does it have memory ports to plug in or expand memory? if so, try turning off any optionsd to use expanded memory. Also, check the website, there maybe a simple soution available there.
Check for Firmware updates as well.
Posted on Feb 16, 2008
SOURCE:
Do i need a memory card for 3310 photosmart all in one
Yes you will need a memory card because the memory on the HP is full. You can delete all the memory in the Hp but need to buy a program to do so. So in the long run it is cheaper to get a memory card for it and it will work just fine for you. Have a great day.
Nov 24, 2012 | HP Photosmart 3310 All-In-One InkJet...
I have a HP photosmart 3310. I'm getting the error:Oxc18a0101 message. I've tried a couple of suggested solutions ut neither has worked. Help!
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone
Try this and it works
Regards,
Ron
Mar 26, 2011 | HP Photosmart 3310 Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Error message shows up on printer screen oxc18a0101
Found this link that tells you how to reset the printer.
http://www.fixyourownprinter.com/forums/printer/39471
Excerpt on resetting the printer from the post linked to above:
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on.
Apr 05, 2009 | HP Photosmart 3310 All-In-One InkJet...
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
414 people viewed this question
Clive
Clive
Thomas F. Schneider
