Question about Kenwood DP-J1070 100-Disc CD Changer
Kenwood DP-J1070 Once the cd is loaded it will not play. I have done what the instruction manual stated but nothing works. Help
    Problem Solver:
  • 7 Answers
I have been experiencing the same problem all of a sudden. Almost like it doesn't recognize that there is any information on the disc(s), regardless of whether it is a CD-R or Original disc. As I looked closer, I saw there is also a small spring connected at the top on the swing arm that pulls the CD in (behind disc indicator light) but it is not connected to anything at the other end of the spring. Just hanging there...I've never noticed it before.
1) Have you found a solution to get your CDs to play?
2) Does anyone have a clue what the other end of this spring is supposed to connect to? Or know where I can find a detailed diagram of the pieces on this part of the device?
Thanks!
Posted on Jul 24, 2010
  • my69 Feb 11, 2011
    I just repaired my cd changer. I also had the spring hanging down between the arm. When I looked closer, the plastic piece at the very bottom of the slot in the arm had broken off, it was under the right tray. I just drilled a small hole in the arm and connected the spring with a small piece of solid wire.
SOURCE:
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Picks 2 disks a a time
This is a synchronization failure between the loading mechanism and the player. Could be due to worn or slipping belts or many other problems
Dec 02, 2012 | Kenwood DP-J1070 100-Disc CD Changer
I want tohook up a Kenwood KA-88 Amp. to a KT-58 Tuner to a DP-M5540 disc player and KA-68W Cassette deck. how do I do it?
Find the manuals or go by the basic INs to OUTs rule. REC = OUT, Play = IN. "Tuner" and "Aux/CD" are not literal. They're for anything BUT a turntable. But remember ONLY a turntable would ever use "PHONO".
This picture shows the rear of the KA-88
http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=168328&image_id=1469879
Register and download the CD manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-DP-M5540-CD-Players-manual/id/479ag101/t/2/
Jun 28, 2011 | Audio Players & Recorders
Does anyone know where the spring on the loading arm hooks to ?
It might be best to try a free download of the service manual from this site. Go to pages 38 and 39 and find out where the spring is located in the exploded views.
Hope this helps
Feb 11, 2011 | Kenwood DP-J1070 100-Disc CD Changer
How do you get to the lens to clean it?
If you've never cleaned the lens, I recommend not doing so. Take it to a repair shop. The lens is difficult to access for the consumer. It is also fragile to handle and may get damaged if not properly cleaned.
Dec 30, 2010 | Kenwood DP-J1070 100-Disc CD Changer
My Kenwood DP-j1070 100 changer is finding cds but not playing anything - there seems to be a spring loose on the loading arm - and not quite sure how to repair - thinking this may be the source of the...
The piece of plastic that held the spring in place probably broke off like mine did. I repaired it by drilling a small hole under the bottom of the slot in the arm and connected it with a piece of solid wire.
Dec 25, 2010 | Kenwood DP-J1070 100-Disc CD Changer
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
The display has failed - Kenwood DPX501U car cd receiver
Same problem as many people who own the kenwood dpx501u head unit. The display has stopped working, pressed the reset button and this has done nothing. Is this a common fault?
Mar 15, 2009 | Kenwood Car Audio & Video
Unlock region code for LG Dp 781 portable dvd player
1) Down load LG5000.zip (google 4 it)
2) Extract and burn content on CD-R
3) Play in DVD and follow instructions
4) DONE
Jan 31, 2008 | LG DP781 Portable DVD Player
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
470 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
