Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
How do i reprogram my HV board?
The board is showing PEO OOO. how do we reprogram the HV board?
  • 2 more comments
  • OLYOJR Mar 13, 2008
    I AM ALSO HAVING THE SAME PROBLEM. I HAVE INSTALLED A NEW HV BOARD BUT THE REPROGRAMMING WILL NOT RESPOND. MINE WILL NOT WORK WITH THE REPROGRAMMING INSTRUCTIONS. THE DISPLAY BOARD IS NOT RESPONDING TO THE COMMANDS, IT IS LIKE I AM NOT HITTING THE BUTTONS. I CAN HEAR THE BUTTONS MAKE A NOISE WHEN I TOUCH THEM. DO I HAVE YET ANOTHER PROBLEM?
  • 123RED Mar 28, 2008
    I am having the same problem. I have installed a new HV control board but the reprogramming will not respond. The refrigerator is dead. I have followed the programming instructions but cannot get the display to respond. Any advice? Thanks
  • maytaghater7 Oct 08, 2008
    \my fridge is doing the same thing. It initially stopped working out of the blue. The only thing that seemed to work on it was the interior light. Digital temp display was blank. Repair man said it was either the electronic display board or the Hv board or both. I bought display board and no change (display blinked a bit but alas went blank again.) So I then replaced the Hv board. Now display reads PEOOOO. I tried these instructions posted and got to about step 5 where you have to enter the code. Couldn't get the code entered, tried a couple times and now I can't even get to that point - started over from step 1 again and nothing. Tried unplugging and plugging back in - nothing. Tried unhooking Hv board and plugging back in - nothing. Please help! I don't know what else to do short of calling a repair guy, and I've alreayd dumped $300 into this. Anyone??
  • paulettegg Feb 07, 2009
    New HV board installed in the rear, now plugged in, reads
    PEO OOO on front of door, no more flashing/flapping noise.
    Cannot move on, only the refrigerator buttons + and - signs when pressed reads H20 or ice for a seconds then reads OOO again please some one help. Door open to program, Do I need to start all over again but all freezes on door panel cannot do anything,
    HELP PLEASE
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Posted on Oct 30, 2007
  • Chancy Smith
    Chancy Smith May 10, 2014
    Thank you! thank you!! You would think that maytag and sears could tell you haw to do this when they sell you the new board. NOPE!! your instructions were sopt on and easy to follow!! thanks! Abilene KS!
  • Shirlene Russo Church
    Shirlene Russo Church Jul 22, 2015
    Thank you! I didn't get any instructions with my new HV board. Your instructions were spot on! The trick is to read them carefully. Once I followed the step by step instructions to get the 'PE' displayed I was home free. Thank you, I'm so pleased with my ability to follow instructions :)
I had a rough time reprogramming my Maytag, the instructions are crappy. First of all open the fresh food door on the fridge(not the one with the control panel) and leave it open. Second hold the door alarm and the freezer temp con - key on the fridge keypad both at the same time. Wait 3 seconds and release the door alarm key. the display will read PE0 000 instead of PE 000.  The plus key on the freezer temp controls the deicimal place and the "REFRIGERATOR TEMP CONT KEYs + & - "controls the numbers. once you enter the code from the serial plate inside your fridge hit press the - key on the freezer temp control until the display starts flashing. Then close the door. click on link below if I confused anyone.
http://www.servicematters.com/maytag_library/docs/16026365.pdf
Posted on Nov 29, 2009
  • repairitMike Apr 16, 2011
    Better reprogramming directions for your Maytag Refrigerator Model#MFI2568AES HV Board after replacement.
    First open fridge and pull the fresh food door in the fridge out to hold the ice dispenser door side open and leave it open.
    Second hold the door alarm and the freezer temp con - key on the fridge keypad both at the same time. Wait 3 seconds and release the door alarm key. The display will read PE0 000 for programming. The plus key on the freezer temp controls the decimal place and the Refrigerator Temp Control Keys + & - "controls the numbers. Once you enter the code from the serial plate inside your fridge press the - key on the freezer temp control until the display starts flashing. Then close the Refrigerator doors and your done.
    New Friend:
ANSWER Hello
You will need to program the control board. Here are the instructions from the manufacture. Hope this helps. Service Specifications Programming Mode: NOTE: The Program Code is located on the Serial Plate on this unit after the word Code. 1. Press and hold the Door Alarm Keypad . 2. Press and hold Freezer Temperature Down Keypad . 3. Release the Door Alarm Keypad and wait 3 seconds. 4. The control will display PE to indicate the programming mode. 5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more. 6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds. 7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press. 8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit. 9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
Posted on Feb 20, 2016
Why is it stuck on PEO OOO?
Did you change a control board? Most times this happens when you change the motherboard and its not programmed for that refrigerator what we're going to have to do is get your model number and there's a code below your model number inside the refrigerator get me that and I'll try to help you find the instructions to reprogram your motherboard
Dec 01, 2015 | Refrigerators
How can I Identify the mother board model of my ACERNOTE LIGHT, Jumper settings, and the processor it can support?
hello ,
please download siw.exe software from google which shows complete details of mother board (information is provided only for drivers installed devices only) its a free software...
GOOD LUCK ooo
Nov 10, 2010 | Acer Computers & Internet
Changed HV board on a Maytag MFI2266AES because ice dispensor and water did not work. Now PEoo ooo is shown on the display where temp read out used to be shown.
Did you check the low voltage supply going to the board? I'm pretty good with that model Only problem is I can't pull that model number up. Looks like you have an extra number or letter. You should get 16 volts from the low voltage side of transformer. Sea Breeze
Oct 15, 2009 | Maytag MFI2266AES Stainless Steel Bottom...
I have a Maytag model no: MFI2568AEB I replaced the HV Control board in the back, when plugged in the front panel now reads PEO OOO and the you cannot put your code in O3O2 all freezes, please help. Thank...
i would unplug and start again,refer may be board.as you seem to know with out that code in there it wont work[been there done that]and you have to read carefully and do just as instructions say to pull it off.you can do it though. God bless ,tom
Jan 24, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Cd player keeps rejecting cd & show an peo-e error on 97 acura cl
PEO normally means Player Error Optical which means that for some reason the cd player is not reading the cd correctly.  This can happen if the disk is dirty or has a lot of scratches.  If the disk is clean and in good condition more than likely the cd player will need to be replaced.
Nov 11, 2008 | 1997 Acura CL
IP Address for LG Shine KE970
it would be best to call or take the phone into your mobile service provider outlet and have them assist you with seeting this up.
Mar 19, 2008 | LG Shine KE970 Cellular Phone
FRONT DISPLAY SHOWS (PE0-000)
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
2,935 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
