Without being in 'reverse safety' mode, I pedaled in reverse, which shut the blades off (OK). But after that, you would turn the blades on but they would only run for a little while. Now it won't even try to turn over the motor. I just got this mower today, so.....Help!!
Thanks,
Mitch
in Mt.Vernon,IL
Unplug the reverse safety switch from behing the console next to the ignition switch
Mitch...the reverse safety switch, I beieve, is designed to kill both the motor and the blades if you don't use the override button prior to trying to mow in reverse. Since I don't know the make or model of your tractor, your not wise to reverse mow unless the override switch is engaged....hope this helps..
