Question about LG KG800 Cellular Phone
Phone won't turn on
I just got my kg800 phone brand new today. After charging it in which the touch pad and LCD screen blink and the battery doesn't show it gaining any life. Which I found the blinking to be odd but wasn't sure if it is supposed to do that.  Any way's after charging it for about 6 hours now it still won't turn on when I press the red button. Anyone else have this problem or know a way to fix it?
Slide up your phone and hold down the off button
Posted on Oct 27, 2007
The screen won't turn on anymore after I took it apart to switch out the charging port.
I see a crack in screen on top right but it should still display (however touch won't work). Look at the ribbon connector which connects display to the phone PCB, it should be firmly secure in its connector.
Also try cleaning the PCB with alcohol, if still doesn't work then either you need a new LCD or some chip is blown.
Nov 10, 2012 | Lands Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
Jun 15, 2011 | LG RUMOR Cellular Phone
Hi. I havbe the ENY phone. Not sure the
its hard to say, possible your battery
go into a dealer and test it out.
good luck.
Oct 01, 2009 | LG enV VX9900 Cellular Phone
LG KG800 charging problem.
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
Jan 21, 2008 | LG KG800 Cellular Phone
Touch pad not working
you may need a new keypad flex - but the chocolate is a touchy phone and usually if the keypad flex is going the slider flex is next - the new shiine is built better
Jan 18, 2008 | LG KG800 Cellular Phone
Screen and touch-pad buttons
1-Check the battery status of u r mobile , charge atleast 6 hours
2-There is problem in display.Than contact LG care center
Nov 08, 2007 | LG KG800 Cellular Phone
Still have a white screen!!
hi how did u get to the screen ?? can u supply info on opening it up cheers
Jul 28, 2007 | LG KG800 Cellular Phone
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
LG KG800 Cellular Phone Logo
73 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
