Question about Motorola Mobility RAZR V3xx Cellular Phone
Soft Key Functions
I can't figure out how to assign different functions to the soft keys despite being able to personalize everthing else.  The soft keys default settings are Options and Main Menu and I would like to change this.  Thanks.
  • Anonymous Dec 12, 2007
    I've always been able to change the functions of my soft keys, I can't fing the option to do that now.
    Brigadier General:
  • 7,752 Answers
I will follow up and let you know
Posted on Aug 18, 2008
SOURCE:
How do I access the functions above the keys?
Depending on the calculator, some are colour coded, so to get the function you want, you hit the associated colour function key and then the key with the function. Some calculators have two different colours, so each key has three functions assigned to it, one without a function key, one with colour key 1, and one with colour key 2.
Good luck,
Paul
Jan 23, 2016 | Office Equipment & Supplies
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Dryer soft touch key pad not working
re install driver for this key pad
Apr 14, 2014 | HP Computers & Internet
What is a soft key
The three buttons just below the display (screen), you can refer to the picture below.. 95e4293.png
No. 8
Good luck. Thanks for using FixYa.
Jun 10, 2010 | Uniden Cordless Phone
V3i switch right and left soft keys
change feature icons & home keys
Change feature icons, soft key labels, and
smart key function in the home screen:
- > Settings > Personalize > Home Screen
> Home Keys
Oct 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
I WANT TO KNOW TOTAL CALL TIME IN W580i
When on the home screen the left soft key takes you to your call history. This is divided into tabs, with the first default tab showing all calls and the other tabs showing incoming, outgoing, and missed calls. Each tab shows a chronological list of calls, displaying the phone number dialed. The currently selected item also shows the date and time of the call. The left soft key is assigned to call the currently highlighted item, while the right soft key opens a menu that provides additional functions. Data counters can be found in the phone settings, as well as total call timers and a message counter.
se_w580i_callhistory.jpg During a call the right soft key is assigned to end the call and the left soft key opens a menu with additional options. These options include the ability to turn the speaker phone on and off, add a call for conference calling, place the call on hold, or enable the mute function. The W580i also supports multi-tasking, so you can access other phone functions like your calendar and contacts while on a call. We found the call management feature set on the W580i to be fairly standard, with nothing that stands out, but nothing important missing, either.
Apr 12, 2009 | Sony Ericsson w580i Cellular Phone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Motorola Mobility RAZR V3xx Cellular Phone Logo
183 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
