Question about Gigabyte GA-K8NF-9 (890552602964) Motherboard
Ga-k8nf9 Main bios checksum error
Hi i have a64 3200+, gak8nf9 1gb ram kingston, chieftec problem is i got "Main bios checksum error" message after flashing bios for k8nf9 ultra,and then dual bios util automaticly is  updating and deleting bios...i dont have permit to use floppy or bios , and compurter is repeating restarting all the time.
i tried to clear cmos and remove batt. , but withot succes
  • 1,006 Answers
Re: ga-k8nf9 Main bios checksum error
0 characters
3 Points
Reason for showing "check main
your bios has been damaged the bios chip on your motherboard could be damaged to check it
restart your compuetr during the boot up process you will see a certain key to press to enter set up (bios) press and hold that key to enter bios using the arrow keys scroll to load optimised defaults
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date.
Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Save, Exit and re-boot and everything should then work.
hope this helps you
Sep 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
I have a GA-G31M-ES2C gigabyte motherboard. when i try to turn the pc on it appears the message "warning! main bios checksum error Retrieving recovery source from HPA" and then the pc reboots...
Take out the memory sticks.Unplug pc first. Then Clear c mos. Put memory sticks back in one at a time.
Reboot on each stick.May be a bad memory stick.
Aug 22, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
try to find a copy of the bios from the manufacture's website, and put it on a usb stick, then start the computer with the usb stick plugged in. if that doesn't work, you may have to replace the bios chip with a properly programmed one. if you can replace it, then you would have to replace your motherboard (unless I missing something here on how to recover the bios)
Jul 07, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Main BIOS checksum error Retrieving recovery source from HPA .............. ..................
download bios and flash whit program if not u have programer creat floppy disk then power on press enter
Dec 24, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Award Bootlock Bios v 1.0 Bios Rom Checksum Error Detecting Drive A media Insert System Disc and Press Enter I have a GA-7VT600 1394 motherboard. How do i fix. Thanks Richard Let me know if you need more...
if you are getting this message it only means that you need to update your bios version, go to manufacturer site and get latest bios update for your motherboard
Nov 23, 2009 | Intel Motherboard
Ref GA-81PE1000L Error message on boot up
all the computer bios settings are stored even when the computer is off (like time and fsb)
these are stored due to the help of a cmos battery
when this battery finishes it gives the CMOS Checksum error Default loaded error
all you need to do is replace the cmos cell
it is a mercury cell (looks like a silver coin) and will be placed on your motherboard
it is very very cheap so go buy one and replace it and be happy
Sep 30, 2009 | Intel Motherboard
You have to change the CMOS battery located on the motherboard...
Mar 28, 2009 | Motherboards
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
Main web site;
Good luck Oliver!
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Cannot load windows
hi cpfish,plz do let me know what kind of error message do you get when you are doing the setup so i can get you the best solution.
May 12, 2008 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-K8NF-9 (890552602964) Motherboard Logo
717 people viewed this question
Top Gigabyte Motherboards Experts
Brian Sullivan
Brian Sullivan
Are you a Gigabyte Motherboard Expert? Answer questions, earn points and help others
